HEI Distributer, Please help
Old Feb 14, 2024 | 04:16 PM
flyrc100's Avatar
Several years ago I ditched the Points and Installed an HEI distributer on my 1971 Cutlass Convertible, 350 engine. All was well until yesterday when the car sputtered and quit. I was able to figure out I had no spark. A further investigation concluded the red "Hot" 12V wire going into the distributer is dead. When you turn the ignition switch to the "On" position this wire should go hot. Not happening. So, what should I look at next? Im thinking ignition switch, but not entirely sure. TIA!
Old Feb 14, 2024 | 04:25 PM
You need to go to the source of where that wire is getting its power from. Most of us use the IGN terminal at the fuse block while others have replaced the resistance wire.
Old Feb 14, 2024 | 05:20 PM
flyrc100's Avatar
The wire did in fact go to the IGN Spade. I noticed the turn signal fuse was blown. After replacing the fuse, the Spade got hot when you turned the key on. Engine fired up.
Old Feb 14, 2024 | 06:44 PM
Investigate why that fuse blew.
Old Feb 14, 2024 | 07:10 PM
Glad you got it figured out. Now look into what Fun71 said.
70 ctls
Sep 6, 2022 06:11 PM
Olds luvr
Dec 17, 2016 02:26 PM
antweave
Mar 11, 2014 04:56 PM
devmar07
Apr 29, 2013 07:26 PM
Olds luvr
Nov 21, 2007 05:24 PM
