Headlights, high and low beam issue
Ok so its raining here today so i haven't had a chance to take a look yet but last night I hit the high beams and just on the left side my low beam light went out. So basically only one beam was working on the left and both were lit up on the right. I've got a 71 cutlass, now these aren't the original lights but .... does this sound like a dimmer switch or do I have a issue in the left side light somewhere??? any ideas
Scott
Scott
Sounds like a issue in left side since the wiring connects to both high beam elements in the light assemblys. Probably either the connector on the low beam light or the bulb it self. The light green should have power when high beams are on. Tan is the low beam.
thanks guys got it working, still not 100% what i did but a little wiggle and there it was, after that i couldn't get it to not work again so must have been a bad ground or connection on that bulb, WEIRD...... Thanks though
Scott
Scott
