Headlight trouble!!!
I have a 71' Cutlass Vert and my driver side low beam only works when the high beam are on. I re-ran a power wire for a amp and swapped radios. Unplug one radion and plug up the new radion..that simple!! I did have to pull the carpet back by the floor dimmer switch...could that be a lose wire by the switch??
Right. On high beam all 4 bulbs should be on. On low, just the two outer bulbs should be on.
The outers have two filiments, one for highm one for low. It sounds like your low filament is out on that one, a common failure mode on sealed beams. The lows are used more than the highs.
