Fuse for F85 1964
The fuse box is located inside, on the left side of the firewall, to the left of where the clutch pedal is (or should be), but higher.
Each fuse slot is labeled with the value of the fuse, but with SFE fuses, each fuse (mostly) is a unique size, so only one should fit in each slot correctly.
You should really have a copy of your Owners Manual and the Chassis Service Manual (at the least), so that you can find this information when you need it.
Since you are some distance from the US, you may find it worthwhile to pay the roughly 25 SFr for a membership to the Automotive History Preservation Society, which will allow you to download a wide variety of manuals and literature for free.
Used, original manuals are readily found on eBay, though, and are also a good idea, as they will be clearer than scans that were done later.
Oldscutty72
Dec 28, 2015 01:56 PM
64oldsf85cutlass
Body work
Jul 4, 2014 07:06 AM
