Firewall grommet 68 442
Old Oct 17, 2010 | 10:17 PM
louie's Avatar
What cables/wires come thru this location that is covered with a bag?, pic from gtr05's post. Thanks for any info.
Old Oct 17, 2010 | 10:50 PM
svnt442's Avatar
That looks like the throttle cable.
Old Oct 18, 2010 | 05:32 AM
Bluevista's Avatar
Registered
That opening is for the vacuum hose for the heater control to vac tank, AC water valve vac line if you have it, vacuum trunk release to the switch.
It's also a common place to run aftermarket accessory gauge lines through.
The accelerator cable comes through a hole to the lower right of that, you can see it in the pic if you look close.
Old Nov 26, 2010 | 10:20 AM
mmurphy77's Avatar
I'm missing the grommet for this exact hole on my '71. My assembly manual has a vague picture with no detail. Does anyone have info on this grommet (i.e. size, holes, availability)? There's a lot of wires and hoses coming out of that hole and I don't think the 'three-hole' style would do it. TIA.
Old Nov 26, 2010 | 10:33 AM
68Tom's Avatar
I just purchased the grommet for my '68 from Fusick for this hole. Fits perfectly. Should have one for the '71 as well.
Conversely, the firewall plug needed to the right of where the brake booster is doesn't fit at all. Not sure if they sent me an incorrect plug or they just don't make one that is correct. Run into this quite a bit on the Olds cars, I've found--they try to use Chevelle items to fit the Cutlass/442 and it doesn't work.
Old Nov 26, 2010 | 01:25 PM
mmurphy77's Avatar
Thanks! I'll give them a call.
Old Nov 26, 2010 | 01:40 PM
hamm36's Avatar
[IMG]file:///C:/DOCUME%7E1/me/LOCALS%7E1/Temp/moz-screenshot-3.png[/IMG] Fusick.com
1968-72 Firewall Vacuum Line and
Wiring Grommet: Fits 1 3/4” Hole in
firewall for A/C Vacuum lines and
wiring.
FG682 Firewall Grommet 6.50
TOM1972
May 13, 2014 06:29 AM
rrupp442
May 5, 2014 03:58 AM
w-30dreamin
Aug 19, 2011 06:09 PM
jmucha
May 14, 2010 04:53 AM
csouth
Jun 11, 2009 06:57 AM
