Factory 8 track into aftermarket radio possible?
Old Nov 4, 2018 | 06:57 PM
BSiegPaint's Avatar
I have the Antique Auto Radio reproduction AM/FM radio installed in my Cutlass and I'm happy with it, running through an amp installed in the trunk and two speakers in the front and in the rear of the car. I have a factory 8 track player I would like to connect to this radio and play through the amp and speakers.
I've identified the important wires coming from the 8 track - a yellow power wire, the black grounds and the two speaker wires for the front and back factory speaker set up. What I would like to do is connect these speaker wires and ground to a 3.5 mm connector and connect it using the AUX input in the back of the stereo. Would this/could this work? I don't know whether the output signal from the 8 track would be too much or not enough for the aftermarket radio connection. How would I tell? I'm no electronic whiz by any means - just willing to try stuff. Is there a better way you would connect the 8 track? Should I use a line output converter? Thanks for any thoughts or suggestions!
Old Nov 5, 2018 | 07:57 AM
The factory eight track units are totally self-contained. The eight track was wired "downstream" from the radio speaker outputs. When not using the eight track, the speaker wires simply passed through the eight track unit and played the radio output. When you put a tape into the eight track, the speaker wires are disconnected from the radio and connected to the amp in the eight track unit. You could do the same thing - run the speaker output from the stereo through the eight track - but the aftermarket stereo speakers probably have a different impedance than the factory ones the eight track was designed to use. If you want to run the eight track through the aftermarket stereo using an AUX input, you'll likely need to go into the eight track and pull off the low-level signal before it gets to the amp in the eight track unit.
Old Nov 5, 2018 | 12:29 PM
BSiegPaint's Avatar
Joe, thank you for the added insight. I have a wiring schematic that should be in the mail today, so I'll be pouring over this all evening. I like the thought of running the power through the 8 track as the factory did it. Lots to think about - I'll be sure and post this up as a "how to" if it works.... I bet I could divert the front speaker wires from the stereo head unit into the player using a line level converter, then out to the amp from the player. When the 8 track isn't on, speaker signal and 12v power goes right though the player and nothing is changed. When the 8 track is in, power to the head unit is diverted, speaker signal is now from the 8 track unit and is sent to the amp - which sends the signal into the 4 speakers as normal. Am I thinking correctly? Would I need another line level converter from the 8 track unit to the amp? This eliminates any thought of using the AUX input on the head unit and makes it operate as factory.
Old Nov 5, 2018 | 12:34 PM
The eight track output is high level, so you'd need another line level converter to route that to your external amp. Alternately, you'd need to go into the eight track unit and tap in where the low level signal enters the eight track internal amp to source the signal for your external amp.
Old Nov 5, 2018 | 12:37 PM
BSiegPaint's Avatar
OK - all possible. I have two units to experiment on, thank goodness. I appreciate the input here - I knew you would know
Old Nov 30, 2018 | 09:30 AM
cjsdad's Avatar
If you are using an amplifier on the stereo unit you will need to get Male-to-Female RCA cords that can be cut to run them to the inputs and outputs of the 8-track. Your stereo output will be in the 500 mili watt range. Your 8-track will have 5~8 watt output so use a line-level converter at the output of the 8-track to reduce it to the same level as the stereo. Running the low level signal through the switch in the 8-track may allow noise to enter the system so make sure you keep the shield connection separated from the vehicle ground to reduce the chance of getting massive noise. If you can connect to the low level signal inside the 8-track like Joe says, you can most likely avoid the line-level converter.
If all that fails to produce quality sound or generates too much noise, a low-level adapter on the 8-track into the AUX port of the stereo may be the easiest route to connect everything.
Old Nov 30, 2018 | 10:52 AM
BSiegPaint's Avatar
Thanks, Dailey - You confirmed what I was thinking, but after really looking at what I want to do, I think I'm stuck with using an RCA to 3.5mm connector and utilizing the 8 track player as an "AUX" input. I dug into the players and there isn't a comfortable way to get to the signal before the internal amp, so I did get a line level converter and installed connectors to an amp using its RCA jacks yesterday, and it works perfectly. I need to mock up the whole system before tearing the whole interior out to run wires everywhere, though. The head unit needs constant power or there won't be a signal to the amp to keep it turned on, otherwise I would have wired up the power as the factory did. Anyway, I'll attach a photo here of my wiring experiment....
Old Nov 30, 2018 | 11:09 AM
BSiegPaint's Avatar
So what I plan to do is use an RCA to 3.5mm connector to go from the line level converter to the back of the head unit AUX input, and then the amp would take the signal from the head unit via RCA cables and then out to the speakers....
Old Dec 24, 2018 | 12:10 PM
BSiegPaint's Avatar
So I did what I described above, and it works perfectly. I used a PAC SNI-35 adjustable line out converter with each speaker lead attatched to the factory speaker wires (blue/black, blue/red) and the ground wires from the unit attaching to the ground of the converter. I attached a separate ground wire to these leads that looped back and attached to the 8 track ground strap at the front of the case. Power went to my ACC at the fuse box. I set the Antique Audio Radio to AUX and push the tape in, and it works like a champ
Old Jun 11, 2019 | 03:19 PM
anthonyP's Avatar
Thanks for posting how you adapted the factory tape deck to the aftermarket and different output Antique Audio Radio. Do you have aftermarket speakers with different ohm and watts ratings compared to OEM speakers? If so, was there any concern with use of the aftermarket speakers and factory tape deck? Does the tape deck work properly and sound okay with the newer style speakers? Does the tape deck work okay with more than two speakers or is that beyond the output of the tape deck?
Old Jun 11, 2019 | 04:14 PM
BSiegPaint's Avatar
The line out converter ends with a 3.5mm plug that inserts into the back of the head unit, and everything runs through that when I switch to the "AUX" mode on the radio. From the radio I ran RCA wires to an amp, and the amp drives four speakers - totally aftermarket, nothing to compare to the factory speakers. So yes, since the output from the tape deck is sent through the converter into the radio, the sound from the deck is perfect. The one thing different is that I had to "balance" the sound level, since the volume and tone outputs still work on the tape deck. I found a happy medium where the volume and tone match up well so when I switch from one to the other the sound level stays the same.
Since the tape deck takes over the AUX mode, the radio cannot play when the tape is in, just like the factory setup.
Old Jun 11, 2019 | 05:37 PM
anthonyP's Avatar
Thank you Bob for the additional information. Pat also has an upgraded OEM radio in his Rallye and installed a factory tape deck. With this information he should be able to follow your lead and wire his tape deck into the radio. It was uncertain if the speakers would be compatible with the tape deck since there are three, and all have a higher ohm rating then the factory speakers.
HitTheHole
Oct 2, 2019 04:27 PM
oldolds2
Jul 23, 2018 12:09 PM
Bee Saint Louis
Oct 25, 2017 04:06 AM
wr1970
Aug 23, 2015 08:37 PM
1970-W30
Nov 2, 2012 10:02 AM
