electrical manual
electrical manual
i have an electrical manual for an 84 cutlass but i need one for a 1980 pre computer i found out there is suppose to be a fuse on the firewall for the blower fan now i am wondering what else has been jury rigged. i got a new ign switch and a new horn relay now to get a dimmer switch. it all started with a short under the hood and melting wires and vacume lines
got the wipers to work and some of the lights but no gauges and the t-top leaked so there is rust in the dash and the circut board is melted in a few places and i haven't been able to find used ones or any g body parts in the wrecking yards around here in spokane. it will take time and money and patients.
In the off chance you don't realize it, your 80 Cutlass is an A-Body (not a G-Body).... If you are calling around asking for G-Body parts, especially without specifying the year, you might not get the answer you want to hear... G-Body designation did not start until 1982.....
my bad i was told it was a g body. what other cars are a-body so i can look in the wrecking yards for a-bodies. good to know about the manuals, does anyone have a service manual for a 1980. i am glad i got on this forum i learn something new every day.
78 - 80 Buick Regal & Pontiac Grand Prix.... Most mechanical & electrical parts are interchangeable.... Body parts are somewhat limited....
And just to be completely correct, GM used the A-body designation on the RWD cars through the 1981 model year. The FWD cars that were SUPPOSED to replace them as the A-body platform weren't released until the 1982 model year. When GM made the (wise) decision to keep the RWD cars in production, the RWD platform was redesignated the G-body. The 1978-1988 cars are pretty much all the same; only the name was changed to protect the innocent.
Yeah, I realize there were some detail changes from year-to-year. For example, the front outer wheel bearings used the A2-style bearing for 1978 only and the larger A3 bearing for 1979-1988. Also, items like wheel lugs changed from SAE to metric threads, wiper switch moved from the dash to the stalk on the column, etc, etc.
Boldsmobile
Dec 13, 2015 07:16 PM
neatolds
Aug 24, 2015 11:57 PM
Boldsmobile
Jan 22, 2011 01:31 PM
Boldsmobile
Jan 22, 2011 01:28 PM
Boldsmobile
Jan 22, 2011 01:26 PM
