The electrical fuse block 67 olds
Old Jan 3, 2013 | 04:48 PM
seanoo's Avatar
Cool The electrical fuse block 67 olds
Any idea why only my instl pnl fuse would not have power to it? All other fuses work with key on?? THere is no power to the fuse or to the back side of the block on both grey and green wires to that fuse. Where should I start looking for the problem? - should I start looking for a break in the wire or could I have a bad key switch??
Old Jan 3, 2013 | 06:22 PM
lemoldsnut's Avatar
How about the headlight switch?
Old Jan 3, 2013 | 06:42 PM
I'd start looking at the wiring diagram in the Chassis Service Manual.
Do you have power from the headlight switch to the green wire?
If not, then you need to work back from there to find the fault.
Old Jan 3, 2013 | 06:47 PM
Check the taillight fuse, on the later cars the instrument panel fuse is powered by the taillight fuse. No taillights=no dash lights. Don't know if the earlier cars are that way.
Old Jan 3, 2013 | 08:44 PM
rocketraider's Avatar
Oldsdruid
I/P and tail lamps are wired thru the headlight switch, so x3 on turn on the head or park lamps and make sure the dimmer on the h/l switch is turned full bright (counterclockwise).
Old Jan 4, 2013 | 08:21 AM
What Glenn said. Power for the instrument panel lights comes from the TAIL LT fuse, into the rheostat in the headlight switch, out to the INST PNL fuse, then to the panel lights. If the **** is turned fully CCW and there still aren't any lights, then the rheostat is bad and you need a new headlight switch.
Old Jan 4, 2013 | 05:16 PM
seanoo's Avatar
Unhappy 67 fuse block problem
I am going out tomorrow to look at the head light switch and go from there.
Will keep all posted. Thanks Dean
Old Jan 7, 2013 | 04:52 PM
seanoo's Avatar
Hey thanks for all the replies, got the panel lights to work for the INST fuse.
Lose wire at the electric block and yes the light switch has to be turn on and rotated in the on position to make sure it works.
What I don't have is Generator and oil light coming on at the dash panel now when you first try to start the car, any ideas??
The bulbs are good and so are the plug pins on the dash electrical board.
Dean:
Old Jan 7, 2013 | 07:26 PM
Oldsdruid
The warning light bulb test works thru a ground contact in the ignition switch. Also make sure you have a good clean ground path at the senders themselves- no teflon tape etc on the threads.
With ign switch ON, remove the wire from the temp and oil senders and ground the wire to a good clean ground point. Idjit lights should light. If they don't work then, it's in the ignition switch or the sender wiring. If they do, clean up the ground path on the senders.
Old Jan 8, 2013 | 05:09 AM
seanoo's Avatar
Will try this tonight and get back to all.
I did order the chassis manual.
Dean
Old Jan 8, 2013 | 06:20 AM
rroth01's Avatar
From: Orion Township Michigan 30 Miles North of the Murder City
I had a similar problem on mine solved it and it helped a few other C/O Members.
Upper right hand corner of the fuse panel had a broken wire inside .
Upper right hand Fuse Holder leading to the instrument panel.
I opened up the panel and there she was.
Once reattatched BINGO.
Oldscutty72
Dec 28, 2015 01:56 PM
CutlassLegend
Aug 19, 2011 11:10 AM
Bobac455
Jul 3, 2011 09:49 AM
slowolds
Nov 19, 2010 08:30 AM
haveoldcutlass
Nov 14, 2010 03:29 PM
