Dome light fuse keeps popping..as well as the radio fuse pops
Old Feb 24, 2014 | 07:14 PM
Oldscutty72's Avatar
When I put the 25a fuse into the accessory fuse spot, at first I can open the driver side door numerous times and it's fine, then something happens and it pops. I take the fuse out and as soon as the new fuse touches the prongs it blows before it's even in place.. And my radio fuse blows and there's a constant buzzing when the car is running.. And suggestions?
Old Feb 25, 2014 | 05:36 AM
1970cs's Avatar
Lansing built
Welcome to C.O.! Well you have your circuits isolated for you. So you need to hook a multi meter set to ohms and go from the load side of the fuse holder and the other to ground if your short is present you will have continuity if so!
Then un-hook each item on that circuit to isolate the item causing the short!
The meter should go to open when you get to culprit.
IIRC Your courtesy lights work off of going to ground when the door opens. When you open the door it could be any accessory lamp or even the door jamb switch power lead maybe contacting metal or even the power wire shorted to ground when slamming the door to make contact?
If you need a service manual for a wiring diagram, join wildaboutcars.com! Free to join and use.
Pat
Old Feb 25, 2014 | 06:39 AM
Pat thanks for the good detailed advice! Gonna run through that. And hope I can figure it out to avoid taking it to a shop.
Shane
Old Dec 8, 2015 | 11:08 AM
aardvark's Avatar
what did it end up being? i'm having the same problem right now and can't find the short.
Old Dec 8, 2015 | 06:01 PM
cjsdad's Avatar
aardvark, Check your cigarette lighter. I have seen quite a few that were loose. To be specific, the lighter end came unscrewed from the ****. This allows the metalic end to droop inside the lighter socket and short it out. This can cause some radios to then blow the ACC/Radio fuse. This is usually just with radios that have a battery back-up lead. Digital stereos for example.
Old Dec 8, 2015 | 06:03 PM
aardvark's Avatar
I read that too about the cigarette lighter. so I pulled mine out completely. and there's still a short :/
Old Dec 18, 2015 | 06:17 AM
radioburningchrome's Avatar
Replacing the door jamb switches did it for me. Had same problem on 1965 Delta and 1980 Cutlass (years apart).
Old Dec 28, 2015 | 01:56 PM
Unknown
Sorry for the late reply, I haven't found the issue yet, haven't had time for awhile to dive into it but after talking to some other people about the issue they all say the same thing. Check your grounds, dead shorts. I'm currently looking into replacing my complete harness, original harness is almost untouched but I had a alarm installed and a few years later started having issues.. Fuses blowing for one.. So I ripped out the alarm system and found a donar original harness for the engine compartment and was able to fix my turn signal issue. When I figure out what is causing my dome lights to not work I will post. Note. I did replace my door jam switch and it did the trick so I thought.. Opening and closing the door about 15 times then the fuse popped again..
71rocket
Dec 8, 2015 11:10 AM
johnnyhawthorn
Mar 12, 2014 05:10 PM
CutlassLegend
Sep 12, 2011 03:28 PM
dc2x4drvr
Sep 14, 2010 08:54 AM
Familio
Mar 19, 2008 10:44 AM
