Does 67 Cutlass rear speaker attach with a bracket?
Old Aug 11, 2009 | 07:58 AM
Flye's Avatar
Thanks to all who have given me some great guidance on the front speaker.
It appears the back speaker was changed at some point (not Delco), and is definitely way beyond its usefulness at this point.
What size should it be?
Does it mount with one of those overlap type brackets or just t-bolt up to the bottom of the shelf?
If it takes a bracket, I guess I can put yet another WANTED ad on here, becuase the one on it is just screwed up to the rear deck metal.
Thanks as always.
D
Old Aug 11, 2009 | 02:41 PM
radioburningchrome's Avatar
Speaker should be 6x9. Carriage bolts or screws will work in place of "T" screws.
Chances are the original speaker had a factory cover that clipped to the magnet. Unless you a doing a 100 point restoration an aftermarket speaker will work.
Gsherman
Nov 7, 2014 08:35 PM
olds70supreme
Feb 9, 2013 09:18 PM
68conv455
Oct 18, 2009 07:36 AM
Southern_Hospitality
May 14, 2009 05:37 PM
HouTXCutlass
Body work
Mar 2, 2009 04:42 PM
