Do I need some kind of reducer for the HEI distributor to tach?
Old Nov 9, 2020 | 08:45 PM
724drcutlass's Avatar
My 72 cutlass originally had just the clock. I know where the wires go but some say because its HEI I need something to work with the coil. Please advise. Thanks!
Old Nov 9, 2020 | 09:38 PM
No, there is a tach terminal next to the coil + terminal, just buy the connector that plugs in to the HEI.
Old Nov 10, 2020 | 07:47 AM
Run to Rund's Avatar
In 1974, I got two HEI distributors from Mike Barnard of Olds engineering and tested them in my 66 W30. He said that the HEI gives a square wave pulse and my factory "sidewinder" tach needed a sine wave pulse, so se sent a tach adapter also. The setup worked fine. More recently (about 2007), I put an MSD box into the Rund car and using a new Auto Meter tach, did not need any adapter, although I got an MSD tach adapter just in case.
Old Nov 10, 2020 | 08:01 AM
Thanks for the info guys, I'll try it this weekend without any adapter.👍
Old Nov 10, 2020 | 11:50 AM
My car has a Sun Super Tach III and works fine with the tach connected directly to the TACH terminal on the distributor as oldcutlass posted above. I can't imagine there being a need for an adapter with a typical aftermarket tachometer.
wyteon
Aug 20, 2018 01:58 PM
ctreutel
Apr 18, 2014 02:02 PM
jjokrm
Feb 21, 2013 08:51 PM
Demonator666
May 18, 2012 09:32 PM
silverriff
Apr 14, 2008 07:00 AM
