distributor
Old Nov 2, 2022 | 03:33 PM
Chuxter's Avatar
1970 Cutlass Supreme
distributor
I have a. 1974 455 out of a 98 thats been sitting quite a while. It does not have any spark. Am I better off rebuilding the stock distributor or just buying a complete after market distributor?
Old Nov 2, 2022 | 03:41 PM
tru-blue 442's Avatar
Old School Olds
Points, condenser or coil could be the problem. I would start with new points and a new condenser.
Old Nov 2, 2022 | 03:43 PM
Chuxter's Avatar
I guess i didnt specify it is an hei distributor
Old Nov 2, 2022 | 05:14 PM
Old School Olds
Bad modulator.
Old Nov 2, 2022 | 05:48 PM
gs72's Avatar
72Cutlass S
First verify you have power to the distributor ( constant 12 volts).
Old Nov 2, 2022 | 06:19 PM
Chuxter's Avatar
Had 12 volt directly to battery with a new clip on distributor cap. I have an inline spark Checker and no flash. I'll pull the module and check it 1st.
Old Nov 2, 2022 | 06:31 PM
It's hard to say without seeing what you have, but the two GM HEI distribtors that I have from the 70s have been working fine for me.
Old Nov 3, 2022 | 03:31 AM
Put a test light on the tach terminal. Turn on the ignition. The light Hoyle be on. If not, verify you do in fact have power to the battery feed to the cap. If you have power, the coil is not likely defective.
Next, crank the engine. Does the test light flicker? If not, either the ignition module or the pickup coil is defective.
Before removing the module, inspect the tiny wire on the pickup coil plug. The wires occasionally break from the constant flexing, meaning no trigger to the module.
Backyardmeinic
Nov 21, 2021 06:35 AM
Dec 14, 2018 01:54 AM
1969442W30
Feb 4, 2018 05:03 PM
oldsmobilty
Sep 28, 2016 06:44 PM
4-ever-olds
Oct 3, 2009 08:51 PM
