Different turnsignal problem 91 olds 88
Old Nov 13, 2007 | 07:14 AM
workinparttime's Avatar
Question Different turnsignal problem 91 olds 88
1st problem
When the turn signals were switched on the indicaters as well as the outside turnsignals would come on but would only blink manually.
2nd problem
Now few days after the first problem. When the turnsignals are switched to on, nothing, no indicaters no outside turnsignals nothing!
Things checked
Hazzards work!
all bulbs work
all fuses underdash checked
Any ideas would be appreciated
Thank you
Old Nov 13, 2007 | 07:46 AM
Oldsguy's Avatar
Past Administrator
Did you check the turn siganl flasher unit? Here is a link to get you going, I searched the wrong car model and one year off.
http://www.oreillyauto.com/EW3/Displ...cycleCount=784
I think the hazard signals work because they use a different flasher unit.
Old Nov 13, 2007 | 08:10 AM
Question Not sure where to find
Thanks for your suggestion
I opened the fuse box and found all fuses and 2 chrome fuse shaped breakers they are marked power wind and power access.
I remember another vehicle I owned had a round chrome flasher in the fuse box but this car doesnt I dont see where the haz flash or the turn flash would be. I checked the owners manual for position with no luck.
Old Nov 13, 2007 | 08:22 AM
correction 92 olds 88
Old Nov 13, 2007 | 04:53 PM
ozoneblue's Avatar
If you remove the lower panel under column it should be visible.If I remember right
Old Nov 13, 2007 | 06:02 PM
Smile Thank you for your help!
TomTork
Sep 14, 2012 03:19 PM
Mattia-SS
Aug 18, 2011 06:08 PM
Pghstarsky
Dec 30, 2007 02:04 PM
Pghstarsky
Oct 15, 2007 04:44 AM
