Dash Dimmer Wire
Dash Dimmer Wire
The yellow wire with Packard connector is power for the radio. Is there a dedicated wire for a light in a radio that is controlled by the dimmer/rheostat from the headlight switch that controls the dash lights? If so, location & color?
The radio light does not dim with the dash lights.
Is there a dedicated grey wire pigtail specifically for the radio light coming off the main or dash harness somewhere? I'm not finding one. I could tap into one of the existing grey dash light wires if necessary. Thanks.
Joe may have been correct after all ... I couldn't find a grey wire dedicated for the radio dial light (or a dedicated black wire for ground). The wiring diagram shows only the yellow (power) lead wire and wires for front and rear speaker. Ground is apparently supplied by the metal plate on the rear dash where the left side of the radio fastens to the dash. No dedicated grey wire in the diagram (or behind my dash). Looks like the radio dial light was powered directly through the radio, not separately, and not through the dimmer / rheostat. The dial light must come on once the radio is turned on. Can anyone confirm?
I'm installing an aftermarket radio manufactured by Antique Automobile Radio - stock appearance for Cutlass 70-72 with modern digital internal components. The radio provides a grey wire for the dial light and a black ground wire. Want to have the dial light wired and operating exactly as original.
Curts1970cutlass
October 2nd, 2015 12:04 PM
olds70supreme
January 25th, 2013 08:08 PM
