CUTLASS SUPREME harrnes problem
Old Mar 17, 2008 | 07:36 PM
ricardo's Avatar
i got a problem with my cutlass engane and light harrnes my car is a 1987 i have got one from a 1984 cutlass supreme it did not fit my car has a v8 350 chevy motor can i use one off a monte carlo ss will it fit i cant find one off a 1987 cutlass
Old Mar 18, 2008 | 03:53 AM
Jim's rare 80's Avatar
Jim's rare 80
Hi. Any G-body harness will work, as long as it also had a Chev V8 Motor. If you pull one yourself, label every plug when you remove it. It will save more time than it takes. Best of luck.
Old Mar 18, 2008 | 04:52 AM
If you're only changing out the under-hood harness, I'll caution that the wire assignments in the firewall connector may not be the same between years. While I don't have firsthand knowledge of the G-body harnesses, I DO know that the 69 and 70 Cutlass engine and light harnesses under the hood are different. I used a 70 harness on one of my 69s and the specific wire locations in the connector are different. You need a good wiring diagram, or at least a thorough side-by-side comparison of the two harnesses at the firewall connector.
Of course, the "right" answer is to stick with an Olds motor...
pappyl
Jun 11, 2023 09:40 AM
Sturgeon
Oct 19, 2007 04:13 PM
luther
Sep 29, 2007 10:41 PM
Classic Cutlass
Feb 15, 2007 04:54 AM
vinoberg
Nov 12, 2006 04:56 PM
