Corrosion in electrical circuits
Old Dec 14, 2005 | 07:12 PM
PetChemMan's Avatar
Post
I seen many posts in the forum about electrical
problems, and I wish to pass on my experience with my 1979 Olds Delta 88. In 1992 I had my Dad's 79 Olds transported up north to me . The car had sat , undriven, in his south Florida carport for about 4 years. Although it had only 32,000 miles, the car was full of electrical problems, with malfunctions in the headlights, tail lights, horn, blower motor, ignition circuits, dash lights, and many more. I spent about three weeks cleaning nearly every accessible electrical contact in the car, including behind the dashboard. Since that initial work, I've put 100,000 miles on the car without another electrical problem, except for the electronic ignition module. The warm, humid, and salty air in Florida may be a bad case, but I suspect other places are just as bad. I used CRC contact cleaner spray, WD-40, and Q-Tips to do most of the cleaning. And, don't forget to clean the electrical body grounds wherever you find them.
Old Dec 15, 2005 | 04:15 PM
texasred's Avatar
Tom Servo's Stunt Double
Post
I concur!
I also eliminated some gremlins in my '71 Cutlass by replacing the ground straps on the back of the block and the battery with larger gauge and adding straps to the alternator to block and block to frame.
C.J.
4WDlifeform
May 7, 2013 11:16 AM
Jolly Green
Jul 21, 2012 07:37 AM
Jolly Green
Jul 19, 2012 08:55 PM
MattD
Oct 28, 2011 02:37 AM
easytobedead
Paint
Apr 10, 2009 06:16 PM
