Correct windshield atenna ?
Old Sep 2, 2017 | 07:31 AM
ben442's Avatar
68 442,
Is this the right one?
The wire off the windshield is that short, won't extend any farther, can the connection float or should it be grounded?
Thanks...
Old Sep 2, 2017 | 07:36 AM
mrolds69's Avatar
It looks about right, it grounds through antenna cable screws.
Old Sep 2, 2017 | 07:38 AM
Originally Posted by ben442
68 442,
Thanks...
You do realize that 68s didn't use the windshield antenna, right? Having said that, I've actually done this swap on a 68. You need to cut the hole in the cowl panel below the antenna connector where that input cable bolts down. 1970-72 cars had it from the factory. Yes, the coax cable connector wants to be grounded. The parts you have are correct.
Old Sep 2, 2017 | 07:44 AM
ben442's Avatar
Thanks, Ben
47 Convertible
Jul 1, 2017 11:24 AM
fahaka
May 29, 2007 10:15 AM
woody
Dec 30, 2006 07:40 PM
72drptop
Oct 9, 2006 04:50 PM
