Convertible hood without motor close?
Old Mar 26, 2013 | 12:55 PM
Oldsmaddin's Avatar
Hi, I have a question.
Can you the convertible hood without motor close?
How to do it?
1968 Delta 88
Greeting Martin
Old Mar 26, 2013 | 01:02 PM
starfire's Avatar
Yes you can. Get a friend to help you (you can do it by yourself, but it's a lot easier with two). Stand in the back seat, grab ahold of the front of the top, and very slowly pull upwards and toward you. It will move up. Keep slowly and evenly pulling it towards the front of the car.
Old Mar 26, 2013 | 01:03 PM
Yes.
Disconnect the hydraulic cylinders on either side of the back seat, then you will be able to move the top by hand.
Watch out, though, it will be heavy.
When these cars were made with non-power tops, they used a large spring on each side in place of the hydraulic cylinders to help with the weight.
Old Mar 27, 2013 | 11:10 AM
Oldsmaddin's Avatar
Thank you very much. With the tip slowly up move has worked.
Two people have submitted.
Greeting Martin
Old Mar 27, 2013 | 11:37 AM
starfire's Avatar
Eric, the hydraulic cylinders should not need to be disconnected. If you were going to manually open and close it many times then I agree, but he should be able to close it once with the cylinders connected without any issues.
Old Mar 28, 2013 | 03:45 AM
Originally Posted by starfire
... he should be able to close it once with the cylinders connected without any issues.
I thought that was what he did want.
Glad you got it down, Martin!
(Or should I say, "Glad you it down got"? - German word order confuses us English speakers.)
Old Mar 28, 2013 | 02:33 PM
Oldsmaddin's Avatar
Hehee, so do we also with English... Google Translator helps but quite well
Bye, Martin
WTony
Mar 18, 2014 12:27 PM
69ishHoliday
Body work
Nov 19, 2013 06:05 AM
Aceshigh
Sep 29, 2010 10:31 PM
Nilsson
Sep 12, 2009 03:26 PM
