connector
Old Jul 20, 2025 | 05:14 PM
groundnpound's Avatar
connector
what does this go to on my 1970 cutlass?
Old Jul 20, 2025 | 05:58 PM
fleming442's Avatar
Looks like an air conditioning compressor with the diode. It can be duplicated with Packard 56 terminal ends.
Although, re-examexamined, it appears to have a capacitor. Every GM car I've seen uses a diode.
Old Jul 20, 2025 | 06:28 PM
Junkman's Avatar
I suggest that you use the wiring diagram in the shop manual to find its application. Look for a green wire (g) and a green wire with a white stripe (g/w).
Old Jul 20, 2025 | 06:34 PM
Is this an original harness or an aftermarket replacement? Is this an A/C car or not? Is that connector part of the engine harness or the A/C harness?
If it's part of the engine harness that runs to the firewall connector, that is for the TCS solenoid. If it's part of the A/C harness that runs through a grommet in the firewall near the distributor, it's for the compressor clutch.
Old Jul 20, 2025 | 07:21 PM
If it's part of the engine harness the object is a 150 ohm 5 watt resistor.
Gene kerr
Jun 2, 2022 08:45 PM
Catdaddy1971
May 29, 2022 02:48 PM
Bee Saint Louis
Jan 30, 2022 10:39 PM
Blackpage
Feb 1, 2016 12:09 PM
Stefano
Jul 8, 2015 09:16 PM
