Cold/Hot Temperature Switch
Old Jul 17, 2017 | 05:11 PM
Vistabrat72's Avatar
Good evening to the forum. Not quite sure, just asking: Vehicle is a 1966 Oldsmobile Ninety-Eight. When cranking the car, as seen in the picture, all the warning lights except the 'HOT' light illuminates in the cluster. Grounding the dark green wire on the sender will allow the hot light to come on, so the wiring/bulb checks out. Is the reason the hot light does not illuminate because the metal strip is (obviously) against the 'COLD' contact in the switch, during the cold start, and there is no way thus for the hot light to come on? Thanking all in advance for help on a probably very simple answer. Regards, Howie.
Old Jul 20, 2017 | 09:41 AM
No responses here, but I did get an answer, the guess I had was correct for anybody else to use should they come across it.
Old Jul 20, 2017 | 11:44 PM
Ozzie's Avatar
Look in your 1966 Oldsmobile Owner Operating Manual. I don't have one for the "B" body cars. The one for the "A" body cars says that the "Hot" light should come on momentarily when starting the car to assure that it is operating correctly. (Page 13.) Your theory may be correct for the 98.
Old Jul 24, 2017 | 03:20 PM
Thank you, should have thought of this, forest through the leaves syndrome at times, but I did prove my theory with a switch already out of a car.
Old Jul 24, 2017 | 04:12 PM
I don't know what you think you proved, but the switch has no relationship to the lamp test function for the HOT light. The ignition switch has a separate green wire with white stripe that provides ground to the HOT light in the START position only to test that lamp. The COLD light doesn't require this because the temp switch grounds that contact when cold and the light comes on anyway. The OIL light is the same way - there is no oil pressure at start so the sender is grounded and the light comes on. The GEN light also comes on normally at start since the alternator is not turning and therefore the field terminal on the regulator is grounded. Only the HOT light requires the extra lamp test wire from the ignition switch. This is shown in the wiring diagram in the CSM - at least it is in my 67 CSM. My 66 CSM isn't readily available at the moment.
Old Jul 24, 2017 | 04:47 PM
jaunty75's Avatar
I think you mean "forest for the trees," as in "can't see the forest for the trees" which means to be so enmeshed in the details that you can't see the big picture.
http://www.dictionary.com/browse/can...-for-the-trees
Old Jul 24, 2017 | 05:58 PM
Exactly! I am human, and do not profess to know it all, not in the least, so I am hoping what I observed was correct, nobody helped until now with an explanation. Thank you Joe for your direct answer as always. Now I understand and when health allows me to crawl around the car, I will start sleuthing for the fault. Thank you folks for the input.
jeremytharper
Jun 26, 2016 10:09 PM
84oldsDelta88
20
Jan 12, 2016 01:36 PM
chip-powell
Jul 22, 2013 01:23 AM
71supreme
Nov 2, 2010 09:10 PM
Oldsproject
Jun 21, 2008 07:03 AM
