Coil wires question
Old Jun 19, 2016 | 08:26 PM
pechetr's Avatar
Coil wires question
I have a yellow wire running from the + on my coil through the firewall into the dash I assume to the ignition but it also runs down to the N terminal on the starter. I just removed the points and swapped to a pertronix ignitor II. Question is does the wire still need to run to both the starter and the coil?
Old Jun 19, 2016 | 09:31 PM
It won't hurt if it does, and it may help.
Old Jun 19, 2016 | 09:36 PM
pechetr's Avatar
As long as it doesn't hurt anything now that I switched to the electronic ignition.
Old Jun 20, 2016 | 04:23 AM
Just provides a full 12V while cranking. Never a bad thing.
Old Jun 20, 2016 | 02:28 PM
pechetr's Avatar
Good to know. Thanks.
Old Jun 21, 2016 | 08:03 AM
jensenracing77's Avatar
Just be sure the one going to the ignition is a full 12+ volts. The Pertronix system can not have the lower voltage from a coil style resistor circuit. The wire would likely be pink or at least stripes if it were a resistor wire but not always.
Old Jun 21, 2016 | 08:13 AM
It depends on which coil he is using as to whether the resistance wire is used:
If there is voltage at the coil in both the start and run positions of the ignition switch without the bypass wire from the starter, I would just tape and stow that wire.
Old Jun 21, 2016 | 08:41 AM
It depends on which coil he is using as to whether the resistance wire is used...
To reiterate what Eric said:
Whether to use a ballast resistor depends on the characteristics of the entire ignition system, but in a practical sense, in our own ignition systems, it depends on the coil, and the coil's internal resistance (actually its impedance, but we won't go there),
If the triggering system itself can tolerate the lower voltage of the ballast resistor, then it is fine to use it that way (HEI's trigger circuit cannot tolerate low voltage, in general most others can).
If you connect full voltage to a Pertronix system with the car's original coil, the coil will perform badly and overheat.
Old Jun 21, 2016 | 10:01 AM
pechetr's Avatar
It is a an MSD Blaster coil.
Old Jun 21, 2016 | 10:37 AM
Look at the instructions for the coil.
Old Jun 21, 2016 | 02:24 PM
Sorry, I was not paying close enough attention to the question. I was referring to the Pertronix module and not the coil. The Pertronix needs at least 12 volts. I believe the Blaster II coil is a 12 volt coil also but not 100% on that.
Old Jun 21, 2016 | 06:05 PM
pechetr's Avatar
Well the solution may have resolved itself. The mini starter I purchased has only two connection points. One to the positive battery and one to the ignition. Looks like the yellow wire will be going to only the coil.
Old Jun 21, 2016 | 08:26 PM
quaddriver's Avatar
4 Barrels of Laughs
From: I moved to pittsburgh so I can be near Primantis
Ditch the ballast resistor with health. That coil is designed to be driven with more volts, more current and multiple sparks per trigger directly from an MSD unit.
Old Jun 21, 2016 | 09:33 PM
pechetr's Avatar
Stupid question, but where do I find the ballast resistor?
Old Jun 21, 2016 | 10:54 PM
It's probably a resistance wire and not a discrete resistor as shown in the diagrams above.
Danny Boy
Jul 28, 2014 01:46 PM
Hawghead
Jul 18, 2014 12:51 PM
dephconn24
May 8, 2012 11:05 AM
dan2286
Feb 5, 2009 06:42 PM
68conv455
Feb 20, 2008 02:36 AM
