Clutch safety switch
Old May 22, 2014 | 04:32 PM
bryndalfly's Avatar
I have a 1970 442 4 speed. To start the car you need to push in the clutch but my clutch pedal is missing the pin that would actuate the safety switch. Can I bypass this switch to get the car started.
Old May 23, 2014 | 12:01 AM
rustyroger's Avatar
'87 Delta 88 Royale
Yes.
Just join the wires either side of the switch and remember to have the car in neutral when you start the engine! .
Did we really have big brother treating us as if we were devoid of common sense back then?.
Roger.
Old May 23, 2014 | 04:09 AM
I think most people did back then, sooner or later.
Old May 23, 2014 | 04:44 AM
jeff in colorado's Avatar
It's a Cutlass.
Not as far back, and maybe not as intelligent a fix but I had an 83 Chevy Cavalier (ugh!) with that switch. I took the connection apart, put a dime in there and never had any issue, was even able to push start it a couple of times. Worst new car I ever had or knew of. Bad paint, lousy rack and pinion steering, throttle body injection went bad, all in about three years.
Old May 23, 2014 | 06:00 AM
bryndalfly's Avatar
Thanks for the help Roger I will give it a try... and your right, big brother thought we were all stupid!!!
Old May 23, 2014 | 07:08 AM
Starting the car in gear and causing damage happens more than people care to admit. Jumping the switch is very easy.
Old May 23, 2014 | 08:15 AM
redoldsman's Avatar
Proud Viet Nam Veteran
That is not as goofy as 1974 when all cars had a seatbelt interlock. You had to have your seatbelt fastened before the car would start. Most dealers disconnected them upon delivery if the customer requested.
Old May 24, 2014 | 09:30 AM
rustyroger's Avatar
'87 Delta 88 Royale
My '88 Buick H body handbook has a section describing how the car will put on you seat belt for you when you get in the car. Mine doesn't have this option, I very much doubt I would have bought the car if it did.
Roger.
Old May 24, 2014 | 10:21 AM
Octania's Avatar
" my clutch pedal is missing the pin that would actuate the safety switch"
How about putting a pin or bolt there and make that functional?
I don't like the Saturn's automatic shoulder belt that you get like it or not whenever it decides to go. You can end up with a shoulder strap but no lap belt.
Stepping on the brake in order to shift out of park is a feature I could do without. Why stop there?
oldspackrat
Nov 17, 2014 06:31 AM
66-3X2 442
Jul 14, 2011 06:08 PM
Dave Siltman
Tech Editor's Desk
May 6, 2010 06:48 AM
My442
Jan 30, 2010 10:35 AM
My442
Brakes/Hydraulic Systems
Feb 17, 2009 06:26 AM
