A/c wiring
Old Nov 20, 2012 | 08:50 AM
Gary's 2 442-S's Avatar
Gary
A/c wiring
I am in the process of hooking up the a/c in my 72 cutlass 442. The wiring harness on the ac is the only one I have not replaced so far. I am not sure what this wiring connector connects to. I know/think that the 2 prong connector to the compressor comes from this connector and I am going to have to fix it but I have looked and cant find anything this connector goes to. Its a 3 prong connector. Anyone have a picture that shows what it connects to or can tell me what it connects to. the other wires are in tack, here are the pictures I have taken
Old Nov 20, 2012 | 12:06 PM
Lady72nRob71's Avatar
Thats the plug where the thermal limiter fuse plugs into. It clips to the compressor bracket. There should be a compressor connector that connects to the empty slot on that one with a green wire.
Picture:
Old Nov 20, 2012 | 01:44 PM
Gary
Picture:
thanks Rob, is the thermal limit fuse what I am seeing plugged into that 3 way connector on the compressor? If so I am going to have to find one of those as well
Old Nov 20, 2012 | 05:08 PM
Yes.
These fuses came from advance autoparts down in South Carolina. I was amazed that they had them in stock! Hope you can find them locally. OPG has them in last resorts.
TIREGUY
Dec 16, 2006 04:10 PM
mainedogg72
Dec 12, 2006 04:45 PM
James
Dec 6, 2004 08:39 AM
stuart
Aug 14, 2004 02:24 PM
