A/C Switch
Old Jul 19, 2018 | 03:53 PM
bigred1972's Avatar
A/C Switch
I have been working on getting the A/C working in my 1972 Cutlass Supreme, the system is charged with r12 and operating. My only problem is that at times the compressor will not turn on unless I move the control lever back and forth from vent to the A/C positions. Can this switch be cleaned or adjusted, when it works everything operates as it should. Any help would be greatly appreciated.
When the compressor does not turn on, I have traced that there is no power from the connection in the A/C control.
Old Jul 21, 2018 | 06:23 PM
cjsdad's Avatar
After years of use, the contact points can develop a varnish like coating on them. It only takes a light cleaning to remove that coating and restore them. If you are handy, you can take the control out of the dash and clean the point contacts. Use a VERY fine sanding paper or cloth. 1500~2000 grit or finer.
If you can reach it in the dash, you can slip the sand paper between the points and clean them in place.
drolds442w30
Apr 21, 2019 10:34 PM
beamer442
Mar 30, 2018 07:27 PM
brettb
Jun 28, 2013 04:52 PM
JBrooks
Tech Editor's Desk
Sep 9, 2012 03:25 PM
RShaips
Feb 25, 2008 05:44 PM
