A/C Heater Fuse
Old Oct 16, 2016 | 02:29 PM
rdhildebrand's Avatar
A/C Heater Fuse
1970 Olds 442 - Blower Motor Works in all Speeds Including High when Moving from Off to Heat, Defrost & Vent, As soon as Control Reaches Normal A/C the A/C Heater Fuse will blow under dash. Any Help will be Appreciated.
Old Oct 16, 2016 | 02:32 PM
Perhaps there is an issue with the AC clutch? Try unplugging the harness from the clutch and see if the fuse stops blowing.
Old Oct 16, 2016 | 02:41 PM
I just got threw unplugging wires at the A/C Clutch Relay Still Blowing the Fuse
Old Oct 16, 2016 | 06:43 PM
Yellowstatue's Avatar
There are three switches on the A/C control panel...The left one turns on the compressor, when the lever gets over to the right, and the middle one puts power (two brown wires) on the third one, the fan speed switch. You must have a short in the wiring on or near the back of the control panel. Or possibly where the wiring passes through the firewall behind the distributor.
Old Oct 16, 2016 | 06:57 PM
Will begin looking for short tomorrow after work - Thanks to all
Old Oct 17, 2016 | 05:25 PM
Ozzie's Avatar
The CSM says that there is compressor hold-in relay (on fender filler) which probably should also be checked. Look for brown & dark green wires. Let us know the solution.
Old Oct 18, 2016 | 03:30 AM
1970cs's Avatar
Lansing built
Ok, you have not followed my diagnostics for shorts that I mentioned over on 442.com a few days ago!
OK someone mentioned a/c relay on the passenger fender. I used those same directions I gave you before. When I found my short I had bumped the cover sideways on my relay just enough to short against the coil while working on something else.
Not saying that the relay or wiring is not the cause, but mine did the following: no matter what setting as long as the fan was on, when you turned the key to power up the car it would blow.
If you use the meter as prescribed, there will be no need to purchase a hand full of 25 amp fuses.
Pat
Old Oct 19, 2016 | 04:39 PM
Finally got to get back to looking for short - Found short in Green Single Hot Wire That Plugs into A/C Relay - Thanks to All !!
Old Oct 19, 2016 | 05:10 PM
1970cs's Avatar
Lansing built
Super job! Glad you founder the bugger.
Pat
Oldscutty72
Dec 28, 2015 01:56 PM
71rocket
Dec 8, 2015 11:10 AM
5998DownUnder
Jun 9, 2014 09:35 AM
96 aurora
Aurora
Sep 6, 2006 03:49 AM
gstangl
Jul 20, 2006 08:53 AM
