A/C on with Heater?
Old Aug 6, 2013 | 09:06 AM
455man's Avatar
A/C on with Heater?
72 Cutlass. I noticed my compressor is kicking on when I put the selector to heat. Is this right or is the wiring messed up somewhere? Compressor comes on also when on def, and norm and max. The vent setting is the only one that does not run the compressor.
Old Aug 6, 2013 | 09:13 AM
rocketraider's Avatar
Oldsdruid
You may have something a little out of adjustment on the control head. DEF, NORM & MAX should engage the compressor. All other positions should not.
I think the CSM shows how to adjust that master switch.
Old Aug 7, 2013 | 07:02 AM
455man's Avatar
I've been looking at the CSM on Wild about cars. I'll have to study it a bit more. Maybe look at a wiring diagram.
Old Aug 9, 2013 | 12:22 PM
455man's Avatar
Still stumped on this. Does the vacuum control when the clutch engages on the compressor?
Old Aug 9, 2013 | 05:02 PM
Lady72nRob71's Avatar
THere is an electrical switch in the control head that switches the compressor - all mechanical. There is also a main system switch that also controls the fan.
The vacuum is only used for hot water valve and air door control.
5998DownUnder
Jun 9, 2014 09:35 AM
zodiacblueS
Apr 7, 2012 02:38 PM
1mech
Aug 15, 2006 11:47 AM
<gerardtsr@aol.com>
Dec 17, 2004 04:46 AM
Chris L.
May 28, 2004 09:44 AM
