brake lights
Old Mar 8, 2007 | 06:13 PM
allthumbs's Avatar
brake lights
the brake lights on my '91 eighty-eight stay on after i turn off the lights and turn off the engine. anyone have an idea? Is this an electrical problem or a brake problem of some kind.
Old Mar 9, 2007 | 04:59 AM
Jim's rare 80's Avatar
Jim's rare 80
Hi. It sounds like an electrical problem. Your brake light switch may have moved to the point your pedal isn't turning it off. Try pulling back on your brake pedal and see if it shuts off. ( I am assuming your switch is at the pedal.) Could be a simple adjustment, or a fauly switch. Good luck, and let us know. Jim.
Old Mar 30, 2007 | 01:11 AM
Jim's rare 80
Hi. How did you make out on the brake lights? If a reply helps with the problem, or if you found out something else, posting the solution may help someone in the future. This forum has helped me in that way. Just curious. Thanks, Jim.
Old Mar 30, 2007 | 05:14 AM
allthumbs's Avatar
thank you. did the trick. the gizmo popped out of the diddlybob. pulled back break pedal while pushing it in and worked like a charm.
Old Mar 30, 2007 | 11:09 AM
Oldsguy's Avatar
Past Administrator
That isn't called a diddlybob, it's a whatchamacallit.
907delta88
Apr 11, 2014 12:33 AM
65droptop442
May 5, 2013 12:21 PM
oldstuff
Sep 13, 2011 08:03 AM
Del70
Aug 2, 2011 04:40 PM
Sid
Sep 10, 2010 02:33 AM
