Blinky Blinky
Old Jul 17, 2013 | 03:37 PM
Sully69's Avatar
Blinky Blinky
My flasher work, but my blinkers don't. I asked about it in a post a while ago and I was told there are two blinker solenoids. I can only see one.
Question: where are they, if there is 2
better, how can I get a wiring diagram?
69 Olds Cutless Supreme
Thanks, in advance
Dean
Old Jul 17, 2013 | 04:15 PM
You just have to keep looking under there, one is for your directional the other for your 4 way hazards. Directional stat is on the fuse box and the 4 way is around the left side of the steering column under the dash.
Old Jul 17, 2013 | 07:16 PM
The hazard flasher is in the fuse box. The turn signal flasher is mounted in a clip behind the dash, to the left of the steering column.
Old Jul 17, 2013 | 08:00 PM
Octania's Avatar
epay for a paper Chassis Service Manual, or, no, AND
sign up at wildabout cars.co and access the CSM as you wish.
Old Jul 17, 2013 | 08:53 PM
firefrost gold's Avatar
was just out looking at my 70 and noticed all the blinkers work all four corners, but the right wont flash with hazards are on the rest will work jus not front right .
Old Jul 19, 2013 | 08:48 PM
Octania's Avatar
BOB [Burned Out Bulb}
Bad wiring or connections at the lamp
faulty switch in the steering column
Again, use the CSM troubleshooting guide, developed by the experts at great expense, to expedite the process.
Old Jul 19, 2013 | 11:44 PM
5998DownUnder's Avatar
Had similar prob with my Olds so I ran a few extra earth leads. Fixed my problem.
