Antenna Options - 68 442 Convertible
Old February 21st, 2018, 10:36 AM
68442Convertible's Avatar
I have a power antenna on the right rear, 68 442 convertible. The original is long gone. A universal Antennaworks automatic power antenna was installed in the 90s. and it has died. There are relays that made it go up when the stereo was turned on (even though the radio was rarely used) so i think that wore it out. Wondering what my options are.
1. Can anyone recommend a new power antenna that is not automatic - that I can raise and lower using the antenna up down switch on the dash? Would need to have two power wires - one for up and one for down. Would also like to get something that fits the sloped opening on my rear quarter better than the Antennaworks.
I am tempted to eliminate the power antenna mechanism because it takes up room in the trunk.
2. Is there a short/stubby antenna that will fit the sloped opening on my rear quarter? I see some stubby antennas for sale, but not sure which ones will fit.
3. Any hidden antenna options that work - other than a new windshield with built in antenna.
68442Convertible is offline
Old February 21st, 2018, 03:46 PM
Yellowstatue's Avatar
The original factory antenna is not automatic. So your mission is, find an original power antenna, '68 or '69 convert or sedan. The original wires are one black, one white as a pair.
Last edited by Yellowstatue; February 21st, 2018 at 03:48 PM. Reason: Forgot something.
Yellowstatue is offline
Old February 21st, 2018, 03:53 PM
Randy C.
rcorrigan5's Avatar
Actually, I believe you can look for power antennas in the '65-'69 model year range. They are all the same for A-body Oldsmobiles (don't know about other GM brands) through those years. But they are all probably going to be expensive!
Randy C.
rcorrigan5 is offline
Old February 21st, 2018, 06:12 PM
allyolds68's Avatar
I put a big car one from a Buick in mine and reused the 442 hardware. The only difference is it goes up a lot higher and doesn’t retract all the way down (I don’t know if the a-body antenna fully retracts either. )
allyolds68 is offline
Old February 21st, 2018, 08:08 PM
Randy C.
rcorrigan5's Avatar
The A-body antenna stops about 2 3/4" above the bezel that holds the assembly in place on top of the quarter.
Randy C.
Old February 22nd, 2018, 02:23 AM
allyolds68's Avatar
Randy C.
my car is in storage but I’m pretty sure mine stops about 6” above the bezel.
Old February 22nd, 2018, 07:04 AM
Is there any source for the OEM hardware that goes on top of the rear quarter?
Old February 22nd, 2018, 07:26 AM
Randy C.
rcorrigan5's Avatar
I believe you are correct. If you can find an original antenna, it usually comes with the top piece. I guess the trick is to find the correct piece for convertibles as it differs from the hardtops. They used to be out there 10-20 years ago but they just don't seem to come up that often anymore.
Randy C.
Old February 22nd, 2018, 07:30 AM
allyolds68's Avatar
Originally Posted by 68442Convertible
Is there any source for the OEM hardware that goes on top of the rear quarter? I think the answer is no.
Ames Performance has a base trim piece that looks correct for the convertible (M122 or M125) and Fusick carries the nut , PAN619 (the Olds nut is different than the Pontiac nut). Ames also carries an entire aftermarket power assembly (M189A) that may or may not work with that hardware. I would call them to find out.
Old February 22nd, 2018, 08:04 AM
The Parts Place may have something.
https://www.ebay.com/itm/1968-69-Cut...haDcHS&vxp=mtr
Thanks for the leads. I will investigate.
Old February 22nd, 2018, 08:20 AM
allyolds68's Avatar
That looks correct.
I used the trim piece from the big car. It was a different part number but was so close in appearance that no one will ever know.
FWIW the hardtop trim piece is completely different. It has a "V" in the top.
Old February 22nd, 2018, 01:18 PM
I ordered the RD1001T from the Parts Place and will see if it fits. I emailed them with questions first and they think it is has the correct 3 parts.
I am leaning toward installing the parts so it looks correct from above, but eliminating the actual antenna mast and motor so I can use the space for something else. I stripped everything out of my trunk - CD changer, amp, subwoofer, spare, antenna - and am reorganizing to get some luggage space.
I did find an antenna on ebay Canada. $1200 US and looks very rough.
https://www.ebay.ca/itm/1968-69-CUTL...xYqGxr&vxp=mtr
Old February 22nd, 2018, 01:24 PM
allyolds68's Avatar
I paid $50 for mine on eBay like 12 years ago and it works great. I sold the old one to Ed Skaff that had a broken mast but the motor worked fine. Unfortunately Ed passed away a year or so ago. It’s probably in a box in his basement.
Old March 29th, 2018, 10:54 AM
Here is what I did.
The RD1001T I ordered from the Parts Place appears to be a repop of the correct 3 parts for the outside of the power antenna. My old Antennaworks antenna fit in the hole - it is a little smaller, so I wrapped some tape around it to keep it centered in the hole. I removed the motorized mechanism from the old antenna, glued a plug in the bottom of the remaining antenna section and sealed everything with sealant. I found a gasket that I put on the underside in a box of old plumbing parts - I think it was from a toilet rebuild kit. What remains is just for looks and is not connected to the radio. I mounted a power amp in the space where the motorized antenna mechanism use to be.
For my actual antenna, I cut a piece of insulated wire 62.4" long, put it between the layers in my convertible top, and attached it to the coax from the radio. The wire is a little longer than normal because I listen to stations at the lower section of the dial.
curtis mayfield
February 21st, 2023 07:13 AM
twilightblue28A
Cars Wanted
October 23rd, 2016 11:23 AM
July 5th, 2012 09:34 AM
Jeff70442
Wheels and Tires
March 23rd, 2012 06:32 PM
gearheads78
July 28th, 2009 07:03 PM
Quick Reply: Antenna Options - 68 442 Convertible
