Alternator choice
Alternator choice
I'm at the point of purchasing a new alternator for my 68 442. Wiring has already been converted (read "hacked") for a 12SI, but I have no idea what the output was of the alternator that was on the car. The car is now equipped with an aftermarket radio and Vintage Air but nothing else fancy.
I can go with either an SI or CS alternator. Recommendations on which to choose and what amperage to consider?
Thanx for your input.
My 71 CS uses a 10DN external Regulator at 63 amps.
I updated it to a 10DN clone that's rated for 100 amps.
I still have the look and functions of an external regulator system, with 60 Amps at 750 crank RPM.
And 100 amps at 1,500 crank RPM.
Just make sure your Alternator power wire is 8 gauge or better.
PS, 100 Amps is the limit for a Single V-Belt.
http://www.qualitypowerauto.com/item...-regulator.htm
442mark
September 30th, 2017 01:06 PM
