94 - no brake lights
Old Feb 17, 2007 | 12:46 PM
margaretia's Avatar
Question 94 - no brake lights
i've got a 94 cutlass supreme and the brake lights don't work. when i press the brake pedal, the high stop light works just not the back ones. the turn signals work and so do the back up lights. i've changed the turn signal flasher and the bulbs and still nothing. any ideas? and yes, i've search the forum and not found my answer...
Old Feb 17, 2007 | 01:51 PM
ozoneblue's Avatar
Question Brake lights
Try turning on the Hazard flashers ,They are on the same curcit ,If they flash in front or are on & not the back check connection in trunk area ,They are two seperate flashers .Also 3rd brake light is seperated at the switch
Old Feb 17, 2007 | 02:15 PM
margaretia's Avatar
Unhappy still nothing
all the flashers work... and the turn signals work... front and back... so now what?
Old Feb 17, 2007 | 08:12 PM
ozoneblue's Avatar
check the plug at T/S harness with 12 volt test light white wire should be stop light input this often burns out. also check the harness under carpet ,these wires break often ,mainly on 4 dr cars,Also do your hazards cancel when you depress the brake
Old Feb 17, 2007 | 09:22 PM
margaretia's Avatar
ok... this is gonna sound stupid. what's the T/S harness??? the car is a 2 dr convertible... i turned of the hazards and they don't cancel when i depress the brake... but the brake lights worked for a minute after i shut off the hazards and then when i depressed the hazard again the brake lights quit working again...
Old Feb 18, 2007 | 05:10 AM
ozoneblue's Avatar
The T/S harness is the wireing form the Turn Signal switch located around lower part of steering column It has a long narrow black plug on the end of it
Old Feb 18, 2007 | 10:09 AM
margaretia's Avatar
what does it mean if the hazards cancel, btw? mine don't but curious now that you've said this... i'm getting under there today and gonna check the T/S harness tho... thank you tons!!! you've been a lot of help!!! muah!
Old Feb 18, 2007 | 12:27 PM
margaretia's Avatar
ok.... i can't find the d@mn thing! aagghhh!!! found something with a white wire, but nothing seems to be loose. did i tell you the brake lights worked for a bit when i messed with the hazard lights switch???
Old Feb 18, 2007 | 04:39 PM
ozoneblue's Avatar
Check the plug with the white wire unplug it look for burn spot at connector . unfortunaly sounds like bad switch,Did you get a test light? handyest purchace for automotive use under $10 I will try to guide you through this .Larry
Old Feb 18, 2007 | 04:55 PM
margaretia's Avatar
i have a test light... am i checking just where the white wire plugs in to the little connector is or trace it to the bigger wire harness?
Old Feb 18, 2007 | 05:46 PM
ozoneblue's Avatar
Do you have power there? with pedel pushed down? If so S/L S/W is ok .you should have power to 3 wires comming out 1 yel 1 grn & dont rember the 3rd without getting book out Larry
Old Feb 18, 2007 | 07:11 PM
margaretia's Avatar
ok... i did that thing ~ pulling on the t/s without it turning on the high beams and the brake lights work (as long as i'm pulling on it)... please tell me there is some way to fix this without having to pull off the steering wheel! i found a website that shows me how to do this but sheesh! what a pain!
Old Feb 19, 2007 | 05:58 AM
ozoneblue's Avatar
Sorry no quick fix.You will need a couple of special tools to do this job Wheel puller & a lock ring spring compressor.some parts stores will loan these out
Old Feb 19, 2007 | 09:49 AM
margaretia's Avatar
so does this sound like its just a loose connection or do i need to get a new t/s switch???
Old Feb 19, 2007 | 12:52 PM
ozoneblue's Avatar
Noyhing really to get loose just worn you might try spraying with electrial cleaner while working all moving parts ,might get lucky & the contacts just dirty.
907delta88
Apr 11, 2014 12:33 AM
65droptop442
May 5, 2013 12:21 PM
oldstuff
Sep 13, 2011 08:03 AM
Del70
Aug 2, 2011 04:40 PM
Sid
Sep 10, 2010 02:33 AM
