87 Olds Fuel Sender Resistance Direction
Old September 26th, 2017, 09:29 PM
kuseetha's Avatar
Dear friends,
Just a small question.
When I connect my multi tester probes between the sender body and the circled connector at the picture, it shows resistance and changes when the floater moves up or down.
Should the resistance go up when the tank fills in (float moves up)? Or the other way round?
kuseetha is offline
Old September 27th, 2017, 04:08 AM
The resistance goes higher as the float moves up. Should be approx 0-90 ohm, 0 empty - 90 full.
oldcutlass is online now
RandyS
September 12th, 2012 02:40 PM
defiant1
May 3rd, 2011 08:52 PM
jag1886
January 12th, 2011 07:37 AM
New'n72
October 10th, 2007 04:42 PM
Quick Reply: 87 Olds Fuel Sender Resistance Direction
