85 Cutlass supreme window problems??
Old Jun 10, 2014 | 09:49 PM
85OLDSCUTTY's Avatar
My driver side window is not working anymore and I don't know what happened. I had a loose wire for a while so every time i wanted to roll a window down i had to connect the wire on the back of the window switch and then roll it up or down.
the other day i went to roll it up and when I connected the wire to the back of the window switch it sparked and the driver side window stopped working.
I can still roll down the passenger window with that switch but not the drivers side.
where do I start I dont want to replace parts that dont need to be replaced any advice?
Old Jun 19, 2014 | 11:47 AM
Hurst/Olds 73/74's Avatar
I have the same problem with the driver's power window on my 1985 442. The switch works for the passenger window, but not the driver's. I removed the switch, cleaned the contacts, and even replaced the switch with another one used from a boneyard. Is there a fuse I can check under the dash? If so, which one covers the electric windows?
chasman414
Jun 25, 2020 07:05 AM
Kotny
Jan 3, 2016 08:04 AM
CuttyLove
Sep 2, 2009 12:32 PM
Rdrokit
May 28, 2009 08:12 AM
88Olds15
Apr 4, 2009 02:25 PM
