'83 98 Regency air vent problem
Old Oct 22, 2006 | 03:04 AM
pompman's Avatar
My dad owns a 1983 Regency 98 and there seems to be a slight problem with the air system. A year ago I removed the radio because it was not working right so I figured I'd check for any loose wires before going out to replace it. After I reinstalled it, the vents were not blowing air even with the fan on max, with the exception of the upper dash vents near the windshield and the two vents on the tranny hump. I checked and there are no loose connections with the hoses, but the front dash vents and side vents by the glove compartment will not give even a whisper of air. Any advice?
Old Oct 22, 2006 | 05:29 AM
ozoneblue's Avatar
Wink Air vents
You must have knocked a vacume line off or pinched one ,Ckeck for Vac leaks,Start with engine & trace back ,Ill usaly remove the line going into firewall & blow cigarett smoke through it while sombody watches dash area & moves controls . Finaly smoking cigaretts does have some good points Larry
Old Oct 22, 2006 | 11:23 AM
volivar's Avatar
Vents
Larry, that smoke thing is a great idea. Gotta tell you, never heard that one before but I think I'll use it.
Old Oct 22, 2006 | 08:25 PM
pompman's Avatar
Thanks Larry, I have a humidor stocked with some good cigars and about half a carton of camels. I'll start on it right away.
84oldsDelta88
20
Jan 12, 2016 01:36 PM
WTony
Sep 12, 2014 06:10 PM
OLDSmobility
Sep 17, 2010 01:24 PM
Fitzgerald
Jul 17, 2010 09:29 PM
GAslim78
Mar 14, 2010 02:24 PM
