69 olds cuttlass convertible
Old Feb 22, 2007 | 01:12 PM
willykmcg's Avatar
I have a 1969 oldsmobile cutlass convertible and the top will only go down it will not come back up. It has worked since i bought it 5 years ago and one day it just stopped. I took out the switch and hard wired it to see if it was the switch but it still does the same thing. Any suggestions
Old Feb 23, 2007 | 04:42 AM
Kennybill's Avatar
Get a trouble light and see if u r getting power at the switch. Possibly bad ground.
Old Feb 23, 2007 | 10:52 AM
texasred's Avatar
Tom Servo's Stunt Double
Is the top motor running at all? Have you checked for power at the switch?
C.J.
Old Feb 23, 2007 | 11:50 AM
willykmcg's Avatar
the motor is running. the switch has three wires one power, one goes down and one goes up. I removed the switch and used just wires but the power to it only goes down and when i connect the wires to go up it has no power. Not sure if there is a relay that might have gone bad or if one of the wires has been cut somehow i traced the wires from the motor to the dash and it looks ok but i can't see where they go behind the dash. Any idea if there is a relay that might have gone bad and where it is located. I have looked in what little manuals they have for this car and can't find anything
gt403
Jun 29, 2014 11:15 AM
jason0820
Mar 6, 2013 07:20 PM
69olds442lover
Oct 18, 2011 11:53 AM
Gixxere
Aug 23, 2011 10:37 AM
djsoldzparrts
May 22, 2008 12:53 AM
