69 Cutlass: how to remove dash gauges?
Hi!!
Would need to replace my gauges bulbs on my 69 Cutlass Supreme, and also fix the non-working clock!
Before I start something, could you tell me how to remove these gauges?
Thanks again!!
Thanks again!!
I did this on my '68 4-4-2 and my '69 4-4-2. About the only way to do it, short of removing the entire dash, is to work behind the dash. There isn't a lot of room but it can be done. You can give yourself a little more room by lowering the steering column, or, a lot more room by removing the steering column. There are two attachment tabs for each pod on the back side, positioned about 4 o'clock and 8 o'clock for each pod, where the pods are held in place by tiny 1/4" hex head screws. Remove those screws, detach the wire harness for each pod, and then take each pod out through the front of the dash.
Randy C.
Randy C.
You can reach all bulbs without taking out the pods, I would only pull the tach.... If all you have to do is fix the clock. It is the easiest of the three to get to and put back in (super easy if you pull your radio) Only two 1/4 inchers to unfasten and three electrical connections to undo.
Hurst/Olds 73/74
May 27th, 2014 07:17 PM
KRICHEN922
July 1st, 2010 09:17 AM
skibone
April 15th, 2004 03:13 AM
