68 Cutlass headlight harness plugs stopped getting power
Was driving home and my headlights flickered then shut off and won't come back on. All other lights are working fine. Checked for 12v as all the plugs and I am not getting power to them. The fuse didn't blow. Any idea what it could be?
I guess this leads to better explanation. I am using a harness from Dapper Lighting which utilized the first 3 prong socket to activate the relay and draws power directly from the battery. I had changed the bulbs to LEDs. Everything worked fine for almost 6 months now until it flickered and wouldn't turn back on. I tested the bulbs and they're still good. I tried different lights. When tracing the harness I noticed one of the original power prongs slipped out of the plugs and was resting on the inner bumper. Could that have shorted something? Kind of strange because all my other lights work fine
I lost voltage/power to the factory headlight plugs. All 4 of them. Because of this it won't trigger my relay harness. I tried both ways. As I mentioned I used a digital meter and was not getting any power to factory headlight plugs
Check for power at the yellow (I think) wire at the dimmer switch. That’s the power feed from the headlight switch to the dimmer switch. No power with the headlights on, start checking wiring to the headlight switch.
