68 88
Old Jun 25, 2009 | 07:50 AM
68delta88oldskool's Avatar
68 88
i have a problem. my dash lifghts stay on in my car an it runs down the battery can anybody help me
Old Jun 27, 2009 | 02:57 AM
Yellowstatue's Avatar
Unhappy Short shorts
If this just started to happen then I would look at the headlight switch or have you just added something electrical to your car... to remove switch, pull out **** all the way (disconnect battery first) then reach under dash and on the end of the switch there is a spring loaded button which you push down and that releases the **** and lets you pull it completely out and allows access to the nut that holds the switch in-
