67 442 (with 425) coolant temperature sensor part number question
Old Oct 19, 2023 | 07:17 AM
matchek's Avatar
Hi, I am looking for a new coolant temperature sensor (I have warning lights, not gauges). I believe I need a single prong temp sensor. When I look up rock Auto and other placed a double prong comes up. When I look up the coolant sensor on Fusick, I get "D1891". When I google D1891 (believe this is the original AC Delco number), I cannot find it anywhere else except on ebay. I ordered one from ebay last week and it was 28 years old and did not work (ohm meter also showed no current).
I don't mind ordering from Fusick but it takes long. Is there another coolant sensor part number with single prong that will work?
If I order the double prong, can I just put the connector on the hot side? How to tell? Thanks!
Old Oct 19, 2023 | 09:19 AM
The temp sensor switch will not show conductivity until it is in a overheat condition, around 240*. Ohming it at room temperature means nothing.
Old Oct 19, 2023 | 09:56 AM
matchek's Avatar
I guess there then is not reasonable way to check that your coolant temperature sensor (warning light) works properly without overheating one's engine.
Old Oct 19, 2023 | 10:34 AM
Boiling water is only 210*, not hot enough to test the sensor. You can carefully test it with a butane lighter flame, just don't get it too hot.
Old Oct 19, 2023 | 11:16 AM
Antifreeze would take the heat enough, if you can heat it outside and not breathe it.
Old Oct 19, 2023 | 12:40 PM
The original temp switch is P/N 1193582, which is AC number D1858. Never use the RockAuto catalog as a reliable source of part fitment info.
Old Oct 19, 2023 | 12:47 PM
matchek's Avatar
Thank you guys. Joe, Amazon has a D1858D, has an extra D on the end. Do you think that would be okay? Perhaps they just made an approvement?
Out of curiosity, how did you find out the correct AC Delco part number? I take it you have the old part list from 1967?
Old Oct 19, 2023 | 02:11 PM
I have no idea what the "D" signifies. Yes, I have a library of original Olds parts books. And note that the sender needs to be correct for the car, not the engine. If you were asking for a sender for a 1967 425, you were going to get the two terminal sender that the full size cars used.
Old Oct 19, 2023 | 02:15 PM
Well, there's no guarantee that the Amazon item photos are in any way correct, but compare this photo of what is supposed to be a D1858D with the one I posted above of D1858.
Old Oct 19, 2023 | 02:18 PM
If all you care about is a sender that works, Standard Motor Products TS11 is about $7.50 at RockAuto.
Old Oct 20, 2023 | 07:20 AM
matchek's Avatar
Thank you Joe - yes, that's all I care about . I coolant sensor that works for a HOT warning light. Will buy.
Old Oct 20, 2023 | 07:46 AM
matchek's Avatar
I bought it just now from Oreilly because I can get it by tomorrow morning by 8 AM for the same total price. What is funny is Oreilly's website says this in not-compatible with a 67 442- look like their inventory is not updated.
Old Oct 20, 2023 | 09:31 AM
Most parts stores rely on manufacturer's application lists, so if one has it wrong, they pretty much all do.
naminator
Aug 7, 2025 01:53 PM
Boilerz25
May 10, 2020 06:07 PM
DonS442
Aug 20, 2019 07:19 AM
65OldsDelta88SuperRocket
Jan 4, 2012 04:38 PM
DAN76
Aug 8, 2009 07:13 AM
