66 f85 nothing works anymore
Old April 13th, 2013, 11:40 AM
1966Oldsmobile's Avatar
Hi,
one day after my car got street legal I want to take a little tour because the weather was very nice. I started the car and everything was OK. One minute later I want to start it again and nothing happens. No Starter, no lights, nothing. I guess a fuse is broke now but I`m not sure. I cheked the wiring diagram but hmmm.
What can be the issue. Thank you very much for your answers!
BR from Austria
1966Oldsmobile is offline
Old April 13th, 2013, 12:04 PM
RandyS's Avatar
Have you tried cleaning your Battery Cables? The terminals can become corroded over time and loose conductivity, or could just be loose? Be sure to check the ground connecton (Negative Battery terminal to block/frame). There are no fuses in the starter circuit or headlights so they should work if there is power.
RandyS is offline
Old April 13th, 2013, 12:11 PM
+1.
Clean battery terminals. The posts and the insides of the clamps should be shiny.
It is easy to have a small area of good contact, with the rest of the connection corroded, and then have this small area of contact vaporize from excessive current flow when cranking the car, causing it to go from "everything working" to "nothing working."
MDchanic is offline
Old April 13th, 2013, 12:19 PM
I will try that! Could it be anything else, broken parts etc.....
The battery itself is OK.
Thank you very much
Old April 13th, 2013, 01:26 PM
Octania's Avatar
To lose everything all at once implies the a major cable or its connection is at fault.
Do you know how to check for voltage drop from one point in a circuit to another? That should pinpoint the issue if cleaning the cables' connections does not do the trick.
You say the battery is ok... how do you know that?
Do the headlights come on? Stay on bright while starter is activated?
Headlights are unfused, outside of a circuit breaker built into the switch.
Often, there is a fusible link between battery and everything on the car's interior. This is where your voltmeter or light bulb base probe will find the fault quickly.
Octania is offline
Old April 14th, 2013, 12:48 PM
Govt slave
squirell's Avatar
check the wires going to the starter at the starter...if they are shorted or melted together you will have nothing....just happened to me
squirell is offline
Old April 14th, 2013, 12:53 PM
lemoldsnut's Avatar
I agree check that wires at the starter. Sounds like that harness shorted. Not that uncommon.
lemoldsnut is offline
Old April 14th, 2013, 02:49 PM
RonFX's Avatar
no power
Hey:
Check the fusible link as mentioned, I owned a 67 Lemans and everything died driving down the road, turned out to be the fusible link under the hood.
Thanks Ron
RonFX is offline
Old April 14th, 2013, 03:30 PM
Govt slave
squirell's Avatar
Originally Posted by RonFX
Hey:
Thanks Ron
Ron,
Can you snap a pix or give a detailed discription of where the fusable link is ?
I have the whole starter harness out and see nothing but the three wires ?
squirell is offline
Old April 14th, 2013, 04:11 PM
RandyS's Avatar
Originally Posted by squirell
Ron,
I do not believe that there is a fusable link on a 66 Cutlass unless it was installed as an aftermarket item.
RandyS is offline
Old April 14th, 2013, 07:32 PM
Govt slave
squirell's Avatar
I concur...at least not under the hood of my 67 I don't see any
squirell is offline
sykosoft
February 1st, 2012 07:22 PM
Col Wickham
October 6th, 2010 12:32 AM
kjr2492
September 21st, 2010 08:59 PM
Jamesbo
February 1st, 2010 07:21 PM
HARDLUCK88
September 27th, 2009 03:57 PM
Quick Reply: 66 f85 nothing works anymore
