66 Delta 88 mystery wire.
Old Oct 3, 2008 | 10:33 AM
ijasond's Avatar
Purveyor of Polyurethane
I've just gotten the engine back in my 66 Delta 88 project & I've gotten rid the old voltage regulator wiring & other wiring that is not needed or was replaced. I'm now left with one yellow wire with black stripe that is not shown on my wiring diagram. I have no idea where it goes or where it came from. Any suggestions? Thanks!
maybe this should be another post, but I figure some of you guys can probably answer both. I've got the power wire connected to the trans switch on the throttle linkage, but I don't know which of the other two connectors is for the kickdown & which is for the pitch, nor do I know which is which on the trans itself. How can I tell?
Old Oct 3, 2008 | 01:16 PM
Oldsmaniac's Avatar
I would say the yellow with black stripe wire comes from the starter solenoid and goes to the coil if I remember right. It provides 12V to coil just when starting then the resistor wire lowers the voltage for running.
Old Oct 3, 2008 | 01:32 PM
ijasond's Avatar
the MSD instructions said to get rid of the resistance wire, so I did that. My coil and everything are wired in good working order. This wire will probably not be needed with my new ignition set-up. thanks
Old Oct 4, 2008 | 04:36 AM
Danny Wiseley's Avatar
The yellow wire with black tracer should be for the transmission control. It connects to the switch on the throttle linkage. The terminal that has voltage (ignition on, engine off) with the throttle in wide open position is the kickdown and should have a white wire. The terminal with voltage at idle is the switch pitch control and should have a black wire.
Good luck.
Old Oct 4, 2008 | 06:28 AM
ijasond's Avatar
Thanks. That's what I needed to know about the switch pitch/kickdown. According to my wiring diagram the orange wire is for the voltage to the switch, not the yellow/black one. I believed this to be correct because the length of the wire & the connector on it were both correct for the switch.
Old Oct 4, 2008 | 07:24 AM
Perhaps, but usually the orange wire is for the oil pressure sender switch.
Old Oct 4, 2008 | 07:55 AM
BILL DEMMER's Avatar
Just the facts...
the orange wire is positively for the transmission control switch. it is the power wire.
bill
Old Oct 4, 2008 | 10:37 AM
ijasond's Avatar
thanks guys. Orange is power for kickdown/pitch & the yellow is 12 volt source from the ignition for the old ignition coil. Everything is a-ok now.
Old Oct 6, 2008 | 11:46 AM
ijasond's Avatar
when I tested the wires to hook this thing up, I had one terminal with power to the pitch at no throttle & the other with power at wot. Now I'm getting power to the pitch wire at no throttle, losing power at mid throttle, then it powers back up at wot. No power to the kickdown side. Did my switch just go bad or what?
JJSCUTLASS
Feb 22, 2014 08:13 AM
Swoopy
Jul 22, 2011 03:39 PM
68cutlassdriver
Mar 6, 2011 11:53 AM
we jeep inn
Apr 11, 2010 10:19 AM
American Lead
Mar 22, 2009 04:09 PM
