66’ cigarette lighter electrical issue
Old Sep 2, 2024 | 04:50 PM
442hurstolds's Avatar
So in the old dash that was in this car, the top had melted due to an electrical fire under the dash due to the infamous cigarette lighter issue. I will not be using the cigarette lighter. Can I still use the hole to put a usb phone charger in or will that be an issue as well?
Old Sep 2, 2024 | 05:57 PM
VC455's Avatar
Barely Registered
Yes.
But ensure that the contacts in the lighter well are corrosion-free. Protect the contact with a copper-containing paste, like Motorex, rated for improving connectivity and reducing chances of recurring corrosion.
The original lighter used about 100 to 150 watts of power to produce a flame on the ciggie. A Micro-USB connector for a phone that charges at 5 V will draw only about 11 watts.
You are proposing to use about one-tenth as much power as the lighter, so the chance of heat getting out of control is that much less.
Old Sep 2, 2024 | 06:21 PM
Originally Posted by VC455
Yes.
alright, thanks. Do you mean the contacts behind the dash or inside the lighter hole? I’ll either using a phone charger usb insert or a Uniden R7 radar scanner with a dash camera plugged into the usb. When the time comes for that I’ll let you know.
Old Sep 2, 2024 | 06:28 PM
Reader's Avatar
good idea replacing the lighter. those things can be dangerous in old cars.
Old Sep 2, 2024 | 06:38 PM
sadly this dashboard met the business end of a bad design as seen in the photo I posted. If I can use it or fix it I’ll do it!
Old Sep 2, 2024 | 06:45 PM
VC455's Avatar
Barely Registered
I meant the lighter hole.
The very best way to proceed would be to connect directly to the lighter wiring behind the dash. That eliminates any risk of high-resistance connection within the lighter hole.
Old Sep 2, 2024 | 07:02 PM
so I put the motorex on the prong behind the dash?
Old Sep 3, 2024 | 12:42 AM
fleming442's Avatar
You can get a direct wire usb doo-dad. I'd lose the socket altogether. What's "motorex"?
Old Sep 3, 2024 | 03:53 AM
mask VC455, he said it not me. It’s a copper paste to prevent corrosion.
Old Sep 3, 2024 | 05:03 AM
VC455's Avatar
Barely Registered
Aye. It's a good thing for every connection in our old cars. Whenever I take any connections apart, I use it when reassembling.
Old Sep 3, 2024 | 08:15 AM
fleming442's Avatar
Ahhhh, something like diabolical grease. I put that stuff on everything.
Old Sep 3, 2024 | 10:34 AM
OLDSter Ralph's Avatar
Lots of people I know that don't smoke and they have cigarette lighters in their cars.
Old Sep 3, 2024 | 10:44 AM
VC455's Avatar
Barely Registered
ahhhh, something like diabolical grease. I put that stuff on everything.
That rated a real LOL, instead of just an L
Old Sep 4, 2024 | 03:05 AM
fleming442's Avatar
I have to give credit to my neighbor for that one. He couldn't remember dielectric and spit out diabolical. It's gotten a bunch of mileage. 🤣
Old Sep 4, 2024 | 08:36 PM
cjsdad's Avatar
That view of the dash looks more like the ignition switch overheated than the lighter. Mine did the same thing but only deformed the dash plastic around the lighter hole. Even with the heat shield in place.
Something like this would solve the problem.
[url=http://Amazon.com: Zennova [2 Pack] 12v USB Outlet,Dual USB Quick Charger 3.0 Port Waterproof Power Outlet 12V Fast USB Charger Socket with Power Switch for Car Golf Cart Boat Marine Bus Truck RV Marine Motorcycle : Cell Phones & Accessories
Amazon Amazon
RonT
Oct 9, 2023 02:16 PM
Tri-Carb
Sep 22, 2021 02:15 PM
slambert
Dec 15, 2017 02:10 PM
Olds24
Nov 9, 2013 10:07 AM
toms66rgtop
Oct 8, 2008 07:02 PM
