57 98 fuel gauge not working
Old Dec 27, 2020 | 02:53 PM
Paddy399's Avatar
Hello all! The title speaks for itself. I had found another thread where someone was working on a 88 with the same issue. Someone mentioned a test where you disconnect the sending unit in the trunk, and the gauge should go to Full and if you touch the lead to ground it should go to Empty. When I have the gauge disconnected, it doesn’t move from E. So instead of touching the lead to ground (because it’s already on E) I used my meter and found I have continuity from the lead from the gauge to ground. Is it safe to assume that the wire to the gauge is grounded somewhere and causing my fault, or is it the gauge itself?
Old Dec 27, 2020 | 03:09 PM
nsnarsk65cutlass's Avatar
Disconnect the gauge if it still has continuity to ground it's the wiring and not the gauge.
Old Dec 28, 2020 | 09:02 AM
Its possible the wire is shorted to ground, disconnect it at the gauge to check.
Old Dec 28, 2020 | 09:51 AM
Paddy399's Avatar
Thanks for the advice, makes complete sense.
Old Jan 2, 2021 | 10:10 AM
Paddy399's Avatar
Update: Disconnected the wire from gauge to sending unit and no continuity to ground, so my wiring seems fine. While I was in the trunk I decided to also test the sending unit side of the connector and I do have continuity to ground on that side.
Ugh, I was really hoping I wouldn’t have to replace the gauge.
Old Jan 2, 2021 | 10:15 AM
Do you have 12v at the other terminal for the gauge?
Old Jan 2, 2021 | 11:52 AM
Paddy399's Avatar
I assume I have power coming into the gauge. There is an 8 pin plug that plugs into the back of the PCB and everything else in the dash works. I’m assuming one pin of the plug is power, that then get distributed through the PCB, then back out one of the 7 other pins to their respective switch/sensor.
I also know what happens when you assume...
smparr
Nov 6, 2021 07:53 PM
jozw30
Oct 26, 2020 01:25 PM
Prodjbm
Feb 11, 2020 06:59 AM
Cruiser Bob
Jun 21, 2019 10:07 AM
Last98
Nov 29, 2011 10:37 AM
