41 olds starter
41 olds starter
I have a 41 olds series 66 with an inline 6 cyl and was wondering if anyone knows what modern starter will bolt right onto the engine so I can do away with the foot switch actuator? Also I'm upgrading the whole electrical system to 12 volt harness and 12 volt battery and starter...I know the points can handle 12 volts but what else do I need to change to run car reliably. Any help here would be great. Thank you
