3V parasitic voltage loss
Old Jul 28, 2016 | 02:35 PM
Big Features's Avatar
Gang, I have a 1968 442 that is draining my battery. My fluke meter is telling me that I have a current draw of 3.012 amps on my battery. I pulled the fuses one by one with no change. Any ideas??
Old Jul 28, 2016 | 03:11 PM
1970cs's Avatar
Lansing built
Try unhooking the alternator. I assume doors closed and accessories were off?
Pat
Old Jul 28, 2016 | 03:24 PM
Pat
Yep goes away if I unplug either the alternator or voltage Reg. I had the alternator tested and it was good. Just replaced the VR as well. How can I be sure which is bad?
Old Jul 28, 2016 | 03:43 PM
You need to follow the current. Fortunately, 3A is a big enough current flow that it should be hard to miss (about 36W is being dissipated).
You have already tried disconnecting all of the fuses. Now go the opposite route:
Disconnect everything from the horn relay and check for current flow from the battery.
Now connect each single connector, one at a time, each one alone, and see which one causes the drain.
Now check the schematic and see what's on that line, and follow it through, disconnecting everything on it, until you find the source.
Old Jul 28, 2016 | 05:59 PM
stellar's Avatar
stellar
Unplug volt reg plug. Test for voltage at disconected plug at #2 wire. If you have voltage there the alt is bad. The set up is (from left to right) F - field 2 stator R 3 battery 4 ign. With key in off position all reg plug wires except 3 should have no voltage. With key in run position 3 and 4 should have voltage. To repeat with regulator plug unpluged test #2 wire. There should be no voltage. If there is voltage a diode is leaking. The alt may test good for output even if the diode is leaking.
Old Jul 28, 2016 | 10:48 PM
I had this issue back in the 90s with my car. It's fairly easy to check diode leakage.
Old Jul 29, 2016 | 05:28 PM
Ok, so update: I replaced my voltage regulator and now the 3 amp draw is gone, but the GEN light is on. Only at idle, it goes away at cruise speed. BACK STORY: I replaced the points with PROTRONICS electronic ignition. After reassembling the car, I got the GEN warning light and replaced the voltage reg and alternator.
Old Jul 29, 2016 | 05:39 PM
Old Jul 29, 2016 | 05:40 PM
Testing the Reg connector, checks out good
Old Jul 29, 2016 | 08:54 PM
That is exactly the symptoms of a leaky diode.
Old Jul 31, 2016 | 06:31 AM
Looks like the Voltage Reg was bad. It was brand new too, just went poof I guess. The car runs perfect now and no loss or idiot lights. Thanks all!
Old Jul 31, 2016 | 06:50 AM
Bad Out Of The Box.
Courtesy of the Great People's Republic and all-around good guys of the Pacific.
Old Jul 31, 2016 | 06:58 AM
jpc647's Avatar
When I went to buy a new voltage regulator, I found two bad ones out of the box. One from advanced, and one from Autozone. One did exactly what yours did, it kept my gen light on. The second one hummed. I know that sounds crazy, but I could hear it hum at low speeds/idle. I ended up buying one from Napa. Only external difference was the napa one was bolted on, where the original was riveted.
Old Jul 31, 2016 | 07:01 AM
Notable Bad Out Of The Bow experiences I've had included SEVERAL condensers and two HEI modules.
If there is an ability to test, always test new parts before leaving the auto parts store.
Old Jul 31, 2016 | 07:13 AM
Bad electrical parts out of the box is not a new issue, I've gotten them since the 70's and not just the chinesium ones. Its frustrating.
71CutlassS455
Nov 14, 2015 05:54 AM
delta_88_germany
Feb 22, 2014 01:48 PM
Dru
Feb 7, 2011 04:08 PM
martine
Jan 3, 2004 11:29 AM
martine
Aug 16, 2003 07:49 AM
