1988 delta 88 no radiator fan and no ac/heater air circulation.
Old May 28, 2026 | 04:58 PM
KitsuneNoTikune's Avatar
Hello, I have encountered a (nother) problem with my 1988 oldsmobile delta 88 royale brougham:
The radiator cooling fan doesn't spin (unless I hook it up straight to the battery), and my ac/heater doesn't blow air.
Can anyone help me with that?
Thanks.
Old May 28, 2026 | 06:27 PM
Both are likely electrical suspect issues. If radiator fan spins when hooked directly to battery, that's a wiring issue. Both AC and heater not blowing air sounds like electrical issue with blower (maybe relay) or wiring. You have a 1988 Oldsmobile Chassis Service Manual (CSM)? If not, you should own one. Firstly, I believe there is a troubleshooting (dichotomous) key/chart in the electrical section of the CSM either in or near the electrical section or w/in the AC/Heater section. Follow the chart. Again, in both cases it suggests an electrical issue. With a simple circuit tester light you need to find where you are not getting power or whether you have a short in one or both of those circuits.
johnnypopwell
Jun 20, 2024 07:15 AM
WesternDevil
Dec 2, 2019 07:27 AM
redoldsman
Jun 27, 2018 03:38 PM
agtw31
Aug 20, 2010 08:45 PM
D Appeldorn
Jun 9, 2010 05:42 PM
