1984 delta 88 starter problems
Old Oct 7, 2011 | 05:06 PM
84oldsDelta88's Avatar
I hope this is in the right section if not feel free to move it.
The car has a swapped 350 now but i'm using the 307 starter and other accessories. Well stupid me forgot to re-install the starter shield when i did the swap.
Today when i was trying to set the timing the motor stalled a couple times. When i tried to restart it the starter cranked very slow and almost barely started the motor, I stopped let it sit 5 minutes and tried again. Half-way through cranking it starts making a horrible grinding noise i released the key from start and the starter was still turning and grinding i even removed the key from the ignition and it was still cranking. I had to run and disconnect the battery cable.
What went wrong here? Did the solenoid go or is the whole starter toast? Can i rebuild it and fix this or is it just better to go and get a new starter or JY one? its only 3 years old I'd hate to let it go to waste.
Old Oct 7, 2011 | 07:23 PM
Classic stuck solenoid contacts - the contact ring welds itself to the contacts, sometimes aided by heat and prolonged cranking.
The larger question, is do you have the right starter installed - they made a smaller starter, and I believe it was for the 307 and 260 (experts please correct me), so it may be too little for your 350.
Old Oct 8, 2011 | 09:15 AM
stellar's Avatar
The original starter is too small. He will need a bigger one, and make sure the battery remains fully charged. A low battery can cause the contacts to stick.
Old Oct 8, 2011 | 01:53 PM
Thanks for the info guys i guess in the near future i'm buying a 350 starter.
But anyway i have a temp fix for now i went to the junkyard and pulled a starter off a 307 just to get me by (looks newer maybe only a couple years old)
So when i got underneath the car i saw a piece of metal that resembled a half egg shell i look up at the starter and saw this (pretty beat, that starter was only 3 years old )
Hopefully the new starter will hold up long enough for me to get a 350 starter.
Is it just me or does that new starter look bigger? It came from a 86 caddy fleetwood.
Old Oct 8, 2011 | 02:11 PM
Yes, the new starter is bigger.
It's probably the one you want. There was also a bigger one for the high compression big blocks, but I think (correctly?) that there were only three sizes.
Old Oct 8, 2011 | 03:06 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
I've never even seen one that small before. No wonder it broke. It was probably from a 260, or something.
The one you pulled from the caddy, looks more like a 307 starter. Large diameter, but the stepped bolt flange.
The 77 and older starters don't have the stepped flange. It's flat and takes 2 long bolts instead of 1 short, and 1 long.
Old Oct 8, 2011 | 03:08 PM
Haha just had a feeling, I didnt even notice until i was looking at the pictures.
Hmm well i hope this bigger one can handle the 350 and dont break in half like the previous one.
But a reman. starter for a 70 cutlass 350 is only 50 bucks at the auto store so if this one kicks the bucket then i'll get the new one i guess.
Well thanks again for all the help fellas. I better get back to work on this thing I'm most likely registering it tuesday and i feel as though i still have so much to do.
Old Oct 8, 2011 | 03:16 PM
Really? Hmmm i bet when i had the shop put the starter in 3 years ago they had a 260 starter laying around and threw it in and to think they charged me about 240 parts/labor to install it (back then i didnt have the tools i have now otherwise i would have done it)
Ooo I see, well do you think this starters gonna last or is it gonna meet the same fate as the other did?
Old Oct 8, 2011 | 09:01 PM
My original gm starter still works fine after 200k miles . Keeps on ticking.
Old Oct 9, 2011 | 07:21 AM
stellar's Avatar
Usually the broken starter housing is caused by incorrect timing. The engine kicks back when the starter is engaged. Get the timing right and the bigger starter will last a while. The bigger starter is a morphidite. GM never made this starter. It has a housing made to adapt to 8MT starter fields. The broken one was a 5MT
Old Oct 9, 2011 | 09:54 AM
You mean it can make little starters all by itself, without even having an alternator to play with?!?
I'm sorry, but that's just WRONG!
Old Oct 9, 2011 | 02:56 PM
stellar's Avatar
NO, that would be a morphodite. The morphidite can't reproduce. Thank goodness my spelling stinks.
Old Oct 9, 2011 | 03:45 PM
Lady72nRob71's Avatar
chasman414
Jun 25, 2020 07:05 AM
Mr.Indeed1988
May 25, 2015 07:03 AM
eazy p
Jun 25, 2013 08:51 AM
Perry615
Apr 16, 2013 05:55 PM
cutlass47
Aug 10, 2009 05:59 AM
