1981 Cutlass-Ignition Switch issues?
Old Jun 18, 2011 | 06:43 PM
LIOlds's Avatar
A month or so ago, I had my 81 Cutlass running-turned it off and when I tried to restart a few hours later had no power at all. The headlights worked as well as the cluster lights-nothing else. I changed out the ignition switch today and the same problem is there. Any ideas anyone has would be great. i dont have an ohm meter unfortunately.
Old Jun 19, 2011 | 12:47 PM
radioburningchrome's Avatar
Possibilities are endless. You might want to purchase a voltmeter to help troubleshoot.
When you turn the key, do you hear a click at all? If the starter solenoid got stuck, you could try tapping it with a hammer to gt it free.
If you do not have 12+ volts at the battery, that would be a good place to start.
Old Jun 19, 2011 | 01:31 PM
LIOlds's Avatar
81 cutlass ignition switch?
No noises at all when I turn the key. I do have headlights and dash lights that dont dim when I turn the key. I also noticed that there's no key/ignition chime. No interior lights at all. All the symptoms led me to think it was the ignition switch. Could a bad ground at the positive cable be causing all this?
Old Jun 19, 2011 | 05:07 PM
jaunty75's Avatar
Do you have anything when you turn the key? In other words, does, for example, the radio work if you turn the key to the ACC or ON position?
Old Jun 20, 2011 | 03:07 PM
LIOlds's Avatar
Jaunty
--Nothing at all when I turn the key. there's no response at KOEO or ACC.
Old Jun 20, 2011 | 04:10 PM
copper128's Avatar
Lt. Buzzkill (ret.)
Is the battery known good?
Old Jun 21, 2011 | 06:30 PM
LIOlds's Avatar
the battery is in good shape
JerseyHarold
Jun 15, 2015 03:01 PM
Six8 x 43
Jun 8, 2015 07:52 AM
Dpc2
Oct 6, 2012 03:44 PM
yeahbuddy
Feb 3, 2010 04:39 PM
toms1966rgtop
May 17, 2009 07:19 PM
