1972 Old/Hurst Pace Car blower Motor
Old Nov 9, 2015 | 08:08 PM
boahook's Avatar
I have a heater and AC blower motor all of the sudden go out on me. Neither the heater or AC work anymore. Do I need a new blower motor and blower motor connection 3 or 4 connector? I notice RockAuto has both of these. Is this a pretty easy installation? Any help much appreciated.
Old Nov 10, 2015 | 03:12 AM
1970cs's Avatar
Lansing built
Do you have a service manual and a test light. The flow chart in the manual will help you diagnose the issue! 25 amp fuse, bad ground, wiring?
Pat
Old Nov 10, 2015 | 06:50 AM
First, the blower motor has a single wire connector. The three or four wire connectors are for the motor speed resistor. Understand what you are buying before spending money.
As for accessing the motor, it is hidden under the passenger side fender. At a minimum you need to remove the inner fender for access. The A/C box is fiberglass, so the blower motor has a separate ground wire since the 'glass box doesn't provide a ground path. It is possible that either the ground or power wire is bad, or the motor itself. This assumes that the blower does not work in any speed position.
kutulu1
Oct 9, 2013 03:25 AM
jroscar
Oct 25, 2012 04:55 PM
jroscar
Cars Wanted
15
Oct 12, 2012 05:47 PM
performance motors
Oct 11, 2012 07:58 PM
performance motors
Oct 11, 2012 12:55 PM
