1972 Cutlass S Wiring
Started restoration many years ago. Purchased new engine wiring harness because old harness was brittle from exposure to elements. Interior / Under Dash wiring harness is good. Decided to remove A/C prior to purchasing engine wiring harness.
Is there a video that will assist my installation of original interior / under dash wiring? It has been a while since I remove from car and unsure of replacement.
Have quite a lot invested in car and do not want it to burn.
Horn Relay / Junction Block
I have asked questions previously in other threads as well as one of my own regarding electrical issues.
I do have an assembly manual and a Fisher Body manual. The assembly manual has no color code and the body manual is incomplete.
My question here is if the horn relay on my 1972 Cutlass S is the junction block as well?
Chassis Service Manual
Is the Chassis Service Manual something different?
If your question is really about wiring SCHEMATIC, you need the Chassis Service Manual, which, for the 1972 manual, has enlarged the color wiring diagram to a more easily readable foldout. The Fisher Body Manual only has wiring for body items like power windows or seats.
1972 wiring diagram foldout:
CSM:
Assembly Manual:
Fisher Body Manual:
Thanks Joe,
I do have the horn relay you show.
I see the location on the assembly manual. I believe I have the correct connections to the horn relay. Section 12 page 170 of the 1972 Cutlass assembly manual shows a wire from the A/C relay to the junction block. My A/C wiring harness has this wire cut and it was a heavy black/orange wire. It was still present at the AC relay but had been snipped just beyond the harness.
Purchased a Console a few years back
Came with wiring harness shown
I have a 1972 Cutlass S Auto
Converting from Column to Floor Shift
Need to purchase Extension between courtesy below dash to this harness
Unsure if this harness will work
Need assistance please
ros6872
June 13th, 2014 09:18 AM
oldzy
September 10th, 2009 05:23 AM
